Question about Dryers
Electric dryer not spinning
Kenmore model # 110.62852100
The dryer is heating up but does not spin.
  • 3,230 Answers
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Posted on Jan 26, 2011
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
No heat spins model; 1106497230 kenmore
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 25, 2010 | Kenmore 62602 Electric Dryer
Will spin but no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 13, 2010 | Kenmore 400 6942 Dryer
Dryer spins does not heat up
I CAN GIVE YOU THE ANSWER TO YOUR TROUBLES. THE HEATING ELEMENT IN YOUR DRYER IS GONE. CALL A REPAIRMAN AND SEE HOW MUCH IT WILL COST TO GET YA A NEW HEATING ELEMENT INSTALLED.
RODNEY
May 16, 2009 | Kenmore 64812 Electric Dryer
The dryer will heat up but will not spin.
ckeck to see if belt has broken.
May 11, 2009 | Dryers
Dryer spin, no heat
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Kenmore 63932 Electric Dryer
On heat in dryer
Bad coil/may be your 220V is tripped,so reset your breaker and re try dryer.The dryer will run on half the power.The other half supplies the current to the heating coil.I'll be happy to help you through this.
May 21, 2008 | Kenmore Dryers
Electric Dryer (Kenmore) It Doesn't spin
The motor has to start to close a switch to let it heat so it sounds like you need a new belt.
Apr 24, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
107 people viewed this question
Top Dryers Experts
