Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
TV cuts off while watching any channel and after some times 1 Minute
The tv cuts off while watching and it does not matter what channel it's on. Can you please tell me what could be causing this problem and how can I fix it
  • Willis Cotton Feb 06, 2007
    also the stand-by light will continue to blink until I turn it back on
When your TV cuts off, does just the video cut off or do you lose all power? Does the power light stay on? If the power light goes out, I would suspect a bad solder connection in the power supply, or maybe a defective capacitor or two in the regulation circuits. If just the video is going to black screen, it could be your picture tube getting weak and the cathode current monitoring circuit is kicking in preventing you from seeing a sub-par picture. Sometimes this can be temporarily adjusted out by a very small amount of tweaking of the screen control located on the CRT drive board, but it is easy to get a shock and hurt yourself if you're not familar with the set. The CRT can sometimes be restored for a bit more life with a CRT tester/rejuvinator that the service Tech has access to if that is what is causing your symptoms.
Posted on Feb 06, 2007
SOURCE:
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
Dec 06, 2010 | HP PL5060N 50 in. Plasma HDTV
Turn on TV and it stays on channel 6 for 1 minute.
the problem probably on the corroded channel and volume switch tri to clean the switch with a contact cleaner...you can buy it on the electrical/electronic store...also check for any corossion at the system ic on yhe main board. there are two big ic on the mainboard one is the jungle ic or chroma and the other one is the system ic which is feets are directly connected to the channel/volume switches
clean the in between of the feets/terminal of the ic.and this will solve the problem
May 20, 2010 | Philips Magnavox TP3285C 32" TV
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
May 03, 2010 | Televison & Video
I have two vip 622 in my house and with one i can watch hd channels on both tv 1 and 2 but on my newest one i can only watch hd channels on tv1 and on tv 2 it says looking for satelite both have identical...
You may have a bad port on the back of the receiver, a cut or disconnected wire somewhere on that side of the system or a bad diplexer if the system is not straight wired to TV2.
The easiest way to verify whether the port on the receiver is bad is to connect that line directly to TV 1 off the back of the receiver. Remember to place TV one on the CHANNEL TO CHECK IF IT IS GOOD. If you have picture then you have a bad diplexer.
Hope this helps. Thanks for using Fix Ya.
Feb 23, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
