Question about Acer Aspire 3000 Notebook
How do i unsegment the hard drive in aspire3000?
Laptop aspire 3000 has a 60 gig harddrive that is segmented into to c and d drive. Anyway I can elimanate the d drive and have 60 gigs on the c drive?
kent@tranzaxtions.com
    Genius:
  • 1,550 Answers
From the link below download the partition manager
Partition manager
This helps to resize the drive without losing any data .
Download home edition
Posted on Dec 04, 2008
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
Pp1020 harddrive
Hi doug160451,
Could you please post the specifications of your laptop, but if your laptop originally came with a 5 Gb Hard Drive then chances are it would be an old laptop and you would do better upgrading to a new laptop than go through the problems associated with upgrading only your hard drive.
Cheers
CptHaddock
Nov 07, 2008 | Compaq Presario Notebook
Hard Disk upgrade
Figured this out...
1)  Flip laptop over, keep front of laptop closest to you and hinges away from you 2)  Remove cover with cylinder/harddrive icon (2 screws) 3)  Remove small single silver screw near the front (close to you) of the laptop in the center of the metal harddrive caddy (the caddy may hold one or two hard drives) 4)  Pull the plastic tab on the left toward the outside of the laptop... the whole caddy with harddrive(s) inside will shift to the left, disconnecting it from the motherboard and lining up the caddy for removal. 5)  Lift the entire bracket straight up
To remove the primary harddrive (the only one present in my model) you must remove the blue L-shaped circuit board from the caddy. 1)  Flip the caddy over 2)  Remove the three screws with slightly larger head diameters around the perimiter of the caddy 3)  Push/slide/jiggle the circuit board so the sata connectors release from the hard drive(s). 4)  Unscrew the hard drive from the caddy
Aug 25, 2008 | Acer Aspire 7720 Notebook
Bios won't reconise 160 gig maxtor harddrive
You could try a BIOS update to increase the size of the Drive the BIOS is able to see.
The second last one indicates that drive sizes are supported over 65GB. It may still not be able to see the 160GB HDD, but this is your only option with this Board. You could always upgrade the Motherboard to support larger drives.
Good Luck.
Apr 24, 2008 | Maxtor HARDDRIVES Hard Drive
Compaq 160 gig
as long as you have a compatible cable to connect your drive i suggest an external 2.5 caddy that works usb then any data you have will be accesable
Apr 09, 2008 | Computers & Internet
Adding Memory To My Laptop
Ok I have the same exact model you do and I have also upgraded my memory, Use a pc2700~DDR 333~SO-DIMM RAM. I upgraded with a simple 512mb chip and it worked wonders, The motherboard can handle up to 2gbs but trust me its not neccesary. also the memory will go in at a 45 degree angle then once it is snug in you will push it down flat till it clicks, feels wierd doing it I know but thats how they are. Also the hard drive is very easy to change, but I would recommend you going with a "western digital 'passport' external usb HDD" I went with the 120 gig and its awesome. The backup software on the harddrive it came with is very worth keeping. Also not sure if you knew this already but that laptop has a 'SiSm760GX' Motherboard and it is supporting the AM2 processor class :) . read up on it here, http://www.sis.com/pressroom/pressrelease_000212.htm anyways hope that helped you and good luck. :)
Nov 10, 2006 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
178 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
