Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
My whirlpool gold doesnt clean properly there is a sandy residue
My whirlpool gold doesnt clean properly. There is a sandy residue left in the glasses and cups, which is really strange as it isn't there BEFORE I wash the dishes!
  • 3 more comments
  • blipp Dec 06, 2008
    No, there wasn't a "milky" residue -- just like a sand stuck to the bottom of the cups and glasses and the insides.
  • lofgrenoldie Dec 06, 2008
    dishes come out with sandy and milky residue
  • justicefour Dec 25, 2008
    my kenmore dishwasher with a built in disposal device leaves sandy residue in glasses and cups.
    It has also stopped draining completely after washes. I have to push the drain button to complete draining
  • Anonymous Mar 26, 2009
    I also had this "white" problem. I did get a water softner and it was amazing the difference. Arizona water is very hard. I still had food particules on my glasses. I just fixed the problem, I hope. The water pipe under the upper tray was unclipped and the water arm was not turning. Just heard today on the TV that lemonaid koolaid cleans dishwashers or rusts and stains. It's much more cheaper if it works.
  • lofgrenoldie May 11, 2010
    does not clean properly - leaves sandy and milky residue on ALL dishes
    Sergeant:
    Champion:
  • 338 Answers
Sounds like you have a calcium issue with your water. if you have a water softner time to get it serviced. also you can get a cleaner for the dishwasher to clean it out called Dishwasher Magic.
Posted on Dec 04, 2008
My glasses end up with sandy residue. Is there a filer and where
no filter like you think the sandy residue is from the detergent and that is because your water is not hot enough.
Mar 14, 2015 | Dishwashers
Our dishwasher doesn't seem to be getting the dishes clean anymore and leaves a residue. We have changed detergents and all that, but to no avail. Is there a filter or something that needs to be cleaned...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a sandy residue on the glasses in the upper shelf after washing--model is Whirlpool Gold GU980SC
heatman101
0-0
Sep 22, 2010 | Whirlpool GU2475XTV Builtin Dishwasher
I have just moved into a home with a 1 year old Whirlpool Gold GU2400XTP Quiet Partner III. THE DISHES ARE NOT CLEAN, GLASSES HAVE WHITE SPOTS, SILVERWARE AND PLASTICWARE HAVE WHITE FILM. I am using...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Sandy grit left on dishes.
I was having a different issue with the same model but I think my issues solution might help yours. My dishwasher was not draining properly. It was the air gap that sits on top of the counter by the sink. It was clogged. We removed it and cleaned it out. Maybe if your air gap is slightly clogged as well it is not allowing the dirty water to flow out properly leaving you with gritty dishes. Hope this helps.
Jul 20, 2010 | Amana 24 in. ADB1200AW Built-In Dishwasher
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Sandy glasses
Are you making sure your heater is ok??Water temp should be taken and be 120 or hotter.If its not turn up water heater temperature.If heating coil is not working replace it.It provides the heat to the D/W and aids in the heated Dry cycle.The solution for spotted/foggy glass problems all  start with making sure your water is Hot enough.Rinse aid is the second.
May 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I have sand in tall glasses when washed on the top shelf
jalexandruna the lid you opened on the dispenser that has 1-6 is where you pour in the rinse aid. As to if it will help or not, this sand issue may be hard water. Try using a eviromentally friendly detergent which is high in Citric Acid. Or try running a dishwasher cleaner like Dishwasher Magic thru the dishwasher to clean this residue out. Hope this helps
Feb 03, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
1,297 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
