Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker will fill when there is still Ice in the tray
The ice maker will fill when there is still ice in the tray. Water ends up everywhere. It does not appear the empty cycle happens, but the machine thinks it did and starts to fill the ice machine again. Could go on for many cycles until I finally get a call from my son telling me there is water on the floor. :-(
I remove the ice maker, empty it out and reinstall. Works for a few weeks even months until I get the next call.
  • steve1719 Dec 04, 2008
    Thanks. I gave it a shot, which it could have been the issue. I have an RO system which feeds the ice maker. It is a distance away, and the ice cubes were small, thus getting caught in the "figures" when dispencing. The Sears Tech rotated the screw to allow a longer filling time, thus giving me bigger cubes. It may have been knocked or moved during some other repair issue. I rotated the screw clockwise and reinstalled. I'll see what happens.
    Thanks
  • Anonymous Jan 17, 2009
    What screw do you adjust?
    Sergeant:
    Champion:
  • 251 Answers
Adjust the screw in the front of the ice maker under the plastic face pull on that there is a screw in there turn the screw till it is almost in and it should limt the problem
Posted on Dec 04, 2008
New turn tap on to fill water and ice up .water goes everywhere through ice maker and into freezer
Sounds like the solenoid that controls the water flow is open. This solenoid operates electrically to stop the water flow after the ice cube tray fills. With out the manufacturer, model, and age of unit I can not offer more information.
Mar 11, 2015 | Refrigerators
The water will not stop flowing into the ice tray after it has filled.
Chances are that the dual water control valve on the ice maker side is defective and not shutting off all the way allowing water to slowly leak by and mess up the freezer with frozen water everywhere. The replacement part is=> WR57X10051 Water Inlet Valve
If the water is simply an extended over fill after ice maker refills that will be caused by the ice maker itself. WR30X10093 Ice Maker Assembly
If you have questions please ask, Thanks Sea Breeze
Jul 11, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag side by side refrigerator with freezer on the bottom water is spraying everywhere when the ice machine comes on. It has the ice / water dispenser on the front. Any ideas?
Check the water line leading to the ice maker for kinks. Also check the filer and ice tray end of the waterline for obstructions or ice that might be deflecting the water to areas other than the ice tray. Let me know how you make out. :^)
May 01, 2012 | Maytag Refrigerators
GE side by side. When ice maker tries to refill water is going everywhere except in the ice tray. Removed ice maker but saw no problem with it. Any hints of what to look for?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Ice not emtying from tray
Sounds is if the ice mold heater is not functioning. This heater warms the bottom of the ice mold just enough to melt the ice and let it drop out. Usually not a repairable item. Replace ice maker assembly - if you're not comfortable doing it yourself, call a repair company.
Mar 20, 2009 | Samsung Refrigerators
Ice maker doesn't work
try as little bit harder and the ice maker should pull out stright from the freezer. watch out for the holders they are on the back and they sometimes are broken if you are not carefull with them. there is also two wire that have to be unconected when you do this. they are moilex connectors and if you push the tabs they should pull apart real easily. Thanks for using FixYa And have a great new year.
Sep 09, 2008 | Samsung RS2578BB Side by Side Refrigerator
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
105 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
