Question about Brother Office Equipment & Supplies
Brother MCF 620CN unable to print, how to clean to prin head.
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
Mix-it-up
  • 832 Answers
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
Posted on Mar 13, 2008
eagle338
  • 4889 Answers
SOURCE: Brother MFC5840 CN Print heads
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the it will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintenance mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of distilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exact mixture of original brother ink.
  • 215 Answers
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Posted on Mar 30, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Unable to cl;ean
Hi Ada,
Go To Below official Brother Printer Video For Your problem,
Still having Problem Then follow Us For
Brother Printer Support
Jan 29, 2014 | Brother MFC-620CN All-In-One InkJet...
Reads "unable to clean"
REINSTALL AND INSTALL PRINTER DRIVER.
FILL THE INK.
MAY BECAUSE OF PAPER JAM.
CHECK YOUR CABLES.PLUG IT PROPERLY
Jan 27, 2011 | Brother MFC620CN Home/Office Color Inkjet...
Mfc-620cn prints all colors but black. went through clean process several times. any suggestions?
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | Brother MFC-620CN All-In-One InkJet...
Error message : ' cannot clean print head'
Unable to clean means the ink absorber is full and needs to be replaced and the counter reset.
Sep 10, 2009 | Brother MFC-620CN All-In-One InkJet...
Cleaning
cleaning here is more like the head cleaning from the print manager.
Jun 16, 2008 | Brother MFC620CN Home/Office Color Inkjet...
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
