Question about Akai LCT2715 27 in. LCD Television
No power indication
Last night my LCD shut off automatically, today there is no indication there is power, no green light.  Screen remains black.  Power is good coming in, but it acts like it is dead.
  • 1 more comment
  • Judith Kadela Dec 05, 2008
    Do I see a pattern here? Does anyone at AKAI see it? TV just went blank -
  • vivkul1 Dec 05, 2008
    Red light is on - so the power is there. BUT green light does not come on - so TV does not power up
  • Anonymous May 07, 2009
    akai Lct3201td power button will come for second and go out...
  • 2,326 Answers
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Dec 06, 2008
I have a dell inspiron 1501 laptop. My computer was working fine last night but i fell asleep and left it on over night. Wwhen i tried to reboot my screen stayed on until it got the welcome screen after...
blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Feb 27, 2013 | Computers & Internet
I have a Sylvania lc370ss9 hdtv. When I turn the power on the set remains black, the power indicator flashes green and the power button will not shut it off.
The set has failed to come from standby to on fully---could be the power board but if it will not power off usually it is elsewhere.
Time to have a qualified shop take a look a get a estimate.
Dec 04, 2012 | Sylvania LC370SS9 LCD TV
Monitor will not light up, black screen.
what is your monitor is it lcd or crt? is the power on indicator of the monitor lights up? which is usually a color green, if it lights up, try to reset the vga cable of your monitor to the video card of your pc and this time do it tightly but not too tight. But if the power on indicator does not light up, the problem lies within your monitor. Have your monitor be check by a professional technician.
http://lcdmonitor-repairsecrets.url-Go.com
Oct 05, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Akai LCT2715 27 in. LCD Television Logo
85 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
