I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to enable my router, printer, and laptop to communicate. Any insight would be appreciated.
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Posted on Dec 29, 2008
How do I print from my Kodak Esp 3.2 printer?
You should find the answer you're looking for, here:
http://blog.laptopmag.com/how-to-set-up-google-print-on-your-chromebook
Aug 08, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
What do I need to connect my Mac osx version 10.6.7 to my new Kodak ESP C110
This printer, using a USB connection to your Mac computer should not be powered on unitl requested during the process on installing of driver / software ask you plug in and power on.
Please go to the link below at Kodak for your model Koadk ESP C110 printer's Mac 10.6 version drivers / software
http://support.en.kodak.com/app/answers/detail/a_id/17378/selected/true
Aug 27, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 printer applemac 10.6 os airport express. printer tries to print but no print appears on paper
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Jan 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a MacBook Pro connected via USB to a Kodak ESP 5 A-I-O. I've been having problems getting the scan function to work at all. So I upgraded the ESP 5 firmware & drivers to the latest available for...
Hi. To make sure that the product hardware is functioning correctly, use the product to make a photocopy. If you cannot make a copy, this solution will not help resolve the issue.
Solution 1:
Follow these steps to restart the product and the computer. NOTE: Make sure that the product connects directly to an electrical outlet and not through a surge protector or power strip.
  1. Shut down the computer.
  2. Press the Power button to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the Power button to turn the product back on.
  6. Try the scan again
Solution 2
1. Replace the USB cable.
2 .Try the scan again.
Solution 3
Fully uninstall and resintall the software and driver of Kodak printer
Workaround:
Try installing the printer to Windows XP environment just to prove functionality and test incompatibility issues. Might be your printer is icompatible with MAC OS. This will also prove if printer is working or not.
Jul 10, 2010 | Kodak ESP 5 Printer
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I install Kodak ESP 3250 all N one print computer wont connect Is
we to were unadle to install such a printer ,customer services usless .they blamed or computer & os our's must be a different copy of windows 7 to everybody elses!!
Apr 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Battling between KODAK AIO 7 vs Dell wireless laptop.
try this
  1. Open the Printers folder:
  2. XP Operating System: Select Start > Settings > Printers and Faxes.
  • VISTA Operating System: Select Start > Control Panel > Printers.
  1. Delete all ESP 7 and ESP 9 printers from the folder. The printers are listed as "KodakESP7+xxxx" or "KodakESP9+xxxx", where xxxx can be any number.
  2. Close the Printers folder.
  3. Press Ctrl + Alt + Delete on your computer keyboard, then select Task Manager.
  4. Select the Processes tab.
  5. Stop each of the following processes. For each process, click the process, then click End Process.
  6. AiOHomeCenter.exe
  • EasyShare.exe
  • EKDiscovery.exe
  • EKIJ5000MUI.exe
  • KodakSvc.exe
  • mDNSResponder.exe
  1. Power cycle the printer. (Press the power button to turn off the printer. Wait approximately 30 seconds, then press the power button to turn on the printer.)
  2. Open the home center software.
  3. Click Install Kodak Printer in the bottom right corner of the home center to add your all-in-one printer to your computer.
let me know if this worked or not.......
May 15, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Going from wireless to USB install
Turn the wireless radio off on the printer so that it is not connected to the router. 1. go to menu-wifi settings and turn it off.
Kindly Go to kodak all in one home center software and click on connect your Kodak printer. select through usb cable and click on next. printer drivers will be installed. go to control panel-printers and faxes and set the printer to default you are ready to go my friend.
Apr 06, 2009 | Kodak ESP 5 Printer
My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Feb 03, 2009 | Kodak ESP 5 Printer
891 people viewed this question
jasbo
jasbo
