Cars & Trucks Logo
Posted on Dec 04, 2008
Fuel pump keep going out in my 2002 isuzu rodeo
I have change fuel pump about four time on this vechile in less than a year it will lose power and strart back firing and i used unlead gas i don't know if that have anything to do with this problem once i change fuel pump it start running just fine for a couple of months
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 04, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
3539
Points
25
Check the relay, it could be stuck in the closed position causing the pump to run 100% of the time the key is on. it should shut off when the fuel pressure is at operating range. like a well pump on a house, it needs to start and stop with the pressure difference. if it runs continuously it will burn up fast.
Good day, I have a 2001 Isuzu Rodeo LS 2WD, manual transmission. A week ago I started having problems starting my truck, seems like the ignition switch was not working, I have to crank it up to four t
Could be your fuel pump failing. Try this; turn ign key to "on", not "start" then off after 5 seconds. Do this several times then try "start". If it starts right up this time, your fuel pump could be going bad, or the fuel pressure is dropping for whatever reason.
3answers
2002 Isuzu rodeo stop while driving wont start
Need more information. Could be fuel pump, fuel filter, crank sensor, cam sensor. Starter??
1helpful
Lose of power 2003 rodeo
Replace fuel filter and see if performance improves if not fuel pump may be weak.
Where is the fuel shut off switch located on a 91 isuzu rodeo v6
This vehicle does NOT have a fuel intertia cutoff switch like Ford vehicles. As a safety shutoff, it uses the oil pressure switch. If the engine stops and loses oil pressure, the oilpressure switch cuts off the fuel pump power. There is NO reset on this vehicle
Why is my2002 isuzu sputtering while accelerating
I own a 2001 IZUZU Rodeo which had the same problem. I chose to ignore this and keep on driving. This was a "bad mistake". Apparently I had been buying dirty fuel. The fuel filter was nearly blocked,the fuel pump had been damaged and a Tank Flush was required. This all meant $$$. Take your vehicle to a "RELIABLE" mechanic.
2002 Isuzu rodeo wont start will start whith starting fluid,replaced pump, fuses and relay have been replaced two,no power to fuel pump
you may have a wire not suppling power to the fuel pump or the ground circuit which you will have to check out.
2002 Isuzu Rodeo 2.2L automatic. Temperature gauge goes to HOT after driving less than a mile. Replaced thermostat, water pump, timimg belt, coolant temp sensor, and radiator. Had system pressure tested,...
Have you tested out your fans? Check your fuses and the actual fuse box. Could be a bad fuse or bad fuse box because I had that happen to me. The fuse was okay (it still had some kind of power going to it ) but the actual box underneath was melted.
1995 Isuzu Rodeo intermitantly loses power at highway speed. I can speed up only by pumping the gas pedal. I replaced the fuel filter and continue to have same problem. Engine seems to shudder and lose...
Since you replaced the filter it sounds like a classic fuel pump problem. Don't know your car but best thing to do is buy a repair manual for your car like haynes or chilton's at your local AP store. Read up on it at the trouble shooting section and the RR section. Good luck.
4helpful
2answers
Wont start 1999 isuzu rodeo
Locate the Fuel Filter and Take it loose. Try to Start the Truck, If the Pump is Good, Fuel will come out of the Fuel line going to the Filter. Please Rate My Response! Thanks!
1helpful
8answers
Fuel pump failure
Has the power supply been checked as constant and spike free?Have you opened up the pump to determine exactly why it failed as that would give you an area to explore.Also make sure the pressure relief valve is working at the fuel rail correctly.check that fuel return line is free and clear
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Isuzu Expert? Answer questions, earn points and help others
