Question about LG 37LC2D Television
Getting a shadow or double image
Just brought the tv home from repair shop took it in because of static type lines, turned out to be the cables i was using. the tv may have bumped around a little from the ride home. Gave it 30 min to warm up in house before turning on.
  • Anonymous Apr 18, 2009
    i have same problem took it to tv repair for software up grade lasted a day and the same problem started again now they are saying i need a new circuit board for loads of cash not had the tv for long other lg works fine this one is **** avoid buying this model cheers bri
Had a connection error 2 wires were crossed
Posted on Dec 05, 2008
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
Hi, im having picture quality problem. kind of a blue shadow mixed with a little orange mostly on top of the screen. you see double of the image in a shadow haze. should I junk this tv or is there a fix...
No,this tv it is fixable and still can be in used for many more years to come.This tv have a problems known as a convergence pictures problems,it is dead.Tv problems have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes this problems.Must have the tv convergence board to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 16, 2011 | Hitachi 57F500 57" Rear Projection...
Images show double images like shadows
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to fix the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement,might still have it.The DLP tvs AKAI and Samsung tvs used the same convergence board.Or the shop,will cost u like 300-350 for parts and labors.
Dec 17, 2010 | Samsung HCM5525W 55" Rear Projection...
VISABLE LINES IN PICTURE
Bulb replacement will only repair reduced brightness or contrast problem. Sometimes shadows or lines (usually curved or circular) appear in the image if the bulb is weak or faulty. This will show with the color turned off and a black and white image displayed.
Most visible color faults are caused by optical engine failure. Big cost, as the complete assembly has to be replaced.
Occasionally there are video processing or tuner problems that require serious troubleshooting to determine what board has to be replaced.
If the fault is not visible on the customer menu and appears only with input signal viewed, you may have a cable box or other signal input problem. Check various input signals to see if the problem is visible with all inputs.
Running the channel scan with vhf input signals sometimes clears up a lot of problems. Your cable company may have changed or adjusted rf modulators or other equipment and the tv needs to be aligned to the changed signal. Auto tuner scans will take care of these problems.
easyab
Apr 22, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Feb 23, 2010 | Hitachi 43FDX01B TV
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Jvc tv model no 65wp74
You have a problem in the convergence circuit. Most likely the stk392-110 ics need to be replaced (with stk392-150's or better) and you are likely to have some burned resistors in this circuit as well.
This really is not a repair that an amateur should attempt, although it's pretty straight forward for anyone experienced with repairing big screen sets. Our shop charges about $300-350 for this repair in your home.
Jan 25, 2008 | JVC AV-27D202 27" TV
No Color
i dd understand that you have a color problem on the tv -you have to repair it - delfo
Jan 06, 2008 | Toshiba 32A50 32" TV
Televison & Video Logo
97 people viewed this question
Computer Repairing
Computer Repairing
