Question about Sharp AL-1540CS All-In-One Laser Printer
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right position. Is there anything else I can do?
    Problem Solver:
  • 11 Answers
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Posted on Sep 04, 2009
How to remove scanner lock on sharp al-1540cs
If you reach up under the left side of the scanner you'll feel a little clear piece of plastic. It rotates about 90 degrees from locked to unlocked. If you unlock it and you want to permanently be unlocked, just pop the plastic thing off with a screwdriver, but MAKE SURE IT'S UNLOCKED BEFORE YOU DO.
Skelton Business Equipment Houston Copiers
Jul 09, 2014 | Sharp AL 1215 Black and White Copier
Its a Sharp AL-1631. It'll copy from the auto feed
Check under the scanner, there is a scanner lock that you may have hit removing copies. Its most likely in the locked position and stopping scan.
Jun 03, 2011 | Sharp AL 1631 Copier
The Sharp AL-1540CS copier produced a sheet all black then gave the error code L-1. The manual said to ''unlock'' the scan head lock, but after looking, it was already unlocked. After restarting the...
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Apr 13, 2010 | Office Equipment & Supplies
Sharp al-1631 error L1
Your copy lamp is faulty or scanner drive is not moving. Check the lamp and replace if not lighting.
If its the scanner, unlock the scanner lock above the paper exit tray.
Nov 25, 2009 | Sharp AL 1631 Copier
Our copier is not copying anything. If you put it
Your copier scanner is lock. if you have a user guide then follow the instruction.How can unlock?and where. I know where is ,it is copier delivery side under scanner or copy board please moving unlock position
Sep 28, 2009 | Sharp AL 1631 Copier
Error code 1 and L flashing alternately
Hello sir; I like you check the scanner unit, the mirrow does move out when you make a copy, you may easy to find out what cause the mirrow not move out.
Jun 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp 1540cs L-1 error, then L-5
Try cleaning the guide bar, then lube it with oil also clean your sensor under your carriage(blow it out with a can of air. If the problem persist check your belt and make sure its tight. You can adjust it from the left rear of the machine behind the Main board.
Mar 26, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Model al-1540cs, copier produce blank copies
THERE ARE TWO CORONA THAT PRODUCES BLANK COPIES, ONE IS IN THE DRUM UNIT ON TOP OF THE DRUM UNIT. THE OTHER IS IF YOU STAND IN FRONT OF THE COPIER OPEN THE COVER TO THE RIGHT, THERE IS A WIRE LOOKS LIKE A GUITAR STRING IF IT IS BROKEN OR MISSING, NEED TO REPLACE. GOOD LUCK
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1540 CS Error
there is a lock on the left hand side ... make sure it is in the unlock position.
Mar 10, 2008 | Computers & Internet
Sharp AL-1540CS All-In-One Laser Printer Logo
138 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
