Question about Sanyo RCPLCXU37 Remote Control
"VIDEO" is stuck on my tv screen
The screen on my Sanyo television is stuck on blue and has "VIDEO" on the upper right side. I have tried to remove this using a universal remote but to no avail.
5 Suggested Answers
  • 38 Answers
SOURCE: need code for sanyo tv (oneforall remote control)
google ..."oneforall remote codes".... there is a site with all the remote codes for most types of oneforall remote controls and even an archive section for older models. follow the instructions and it will lead you to the proper codes. i have used the site several time with great success.
good luck , jay
Posted on Mar 21, 2009
  • 60 Answers
SOURCE: i need the codes for a GE Universal remote for my
Posted on Feb 23, 2010
  • 2080 Answers
SOURCE: How do i turn on the caption with universal remote RCr311W to a sanyo tv moel#DS27820 ?
Here is the link to the User's Manual for that universal remote control:'s/RCR311W_DOC_OM.pdf
Unfortunately there is no dedicated button on that particular universal remote for operating the Closed Captioning feature on your TV.
You can try using the MENU button on that remote in order to access the AUDIO OPTIONS on your TV. Then see if you can activate the CLOSED CAPTIONING from there. See page 5 of the above manual for instructions on how to operate the MENU button on that remote.
Otherwise you will have to use the original factory remote control that came with the TV, or go out and buy a more expensive / advanced universal remote control with all the additional features and buttons that you require.
Good luck.
Posted on Dec 09, 2011
  • 100 Answers
SOURCE: how do I do a code search on a sanyo fxya universal remote
Hi Paul
Have a look at this PDF document
Posted on Feb 22, 2012
  • 46 Answers
SOURCE: what is the code to the TV using a Sanyo universal
YOU CAME TO THE RIGHT PLACE.. FREE UNIVERSAL REMOTE CODES AT or visit the site, there is a link on left side, scroll down,, click on remote codes.. there is no direct button to that page.
Posted on Mar 16, 2012
0 characters
1 Points
I need to change the tv to HDMI
A puzzling question Seth
To change a television to HDMI, you just scroll through the Input choices using the remote until you get to the HDMI socket the 'signal' is connected to.
The TV is Sanyo? Why do you need a Phillips remote? Why do you have to format the television?
Direct TV is your television signal supplier which doesn't have a lot to do with anything :>) The box has an HDMI socket? You connect an HDMI cable to the HDMI socket on the television and I refer you to my first paragraph.
Dec 11, 2015 | Remote Controls
My TCL TV has a blue screen saying no signal. What button do I push on my new universal remote to get my cable tv
the button will be labeled either source, input, tv/video. if the direct TV remote was programmed for your television there is a tv/input button
Nov 03, 2013 | Remote Controls
The cat sat on my remote now the tv is locked and i dont know how to unlock it. it is a palsonic 5140ts old model tv
Is the screen blue, with a little lock icon in the upper-right corner? Press an hold the MUSIC button on the remote until the lock icon disappears.
Aug 16, 2010 | Remote Controls
I need remote code for a sanyo TV
try this
TV Sanyo 0154, 0159
Jul 31, 2009 | Remote Controls
I need to un-zoom my sanyo television set. How do i do this with a RCA universal remote (rcu600m)?
I am not positive that this will work for you, but it did for me. I have a Sanyo tv set that was stuck zoomed in. I have mediacom and a remote that is given with the cable box that was programmed to work on the tv, on this remote at the bottom the "#" button says "Aspect" above it and after pushing it the problem was fixed. I hope this helps.
May 07, 2009 | RCA RCU600M Remote Control
TV stuck on blue video screen
This usually happens when you are on a source that doesn't have a signal such as a channel with no signal or an AV input that is not connected.
You should look for a button that has TV/VCR or TV/VIDEO on it. I've guessing that you've already tried to change the channel but if not try that.
Last ditch effort in that case may be to unplug the TV for a few secouds. Warning- this may wipe out any settings you have entered such as the channel programming (which channels to skip while surfing) but along with that goes the blue screen.
Jan 11, 2009 | RCA Universal Remote Control
Greetings Giselleriver,
Since you have the CT9951, I can only assume you have a CF27H50, CF32H50, or CF36H50 TV. You just need to make sure you have your video sources (i.e. VCR/DVD/Cable Box) connected to Video 1 or Video 2.
Once you have your video sources connected if you press the PIP button you should have a small screen that appears in the upper right hand corner, if you press it again it should grow slightly. To change whats in the window you should be able to press the SOURCE button, and if you want to exchange what your watching on the main screen the SWAP button should exchange the images.
If your not use one of the listed TV's and your unit doesn't come with the PIP feature, you can't install a PIP feature.
Happy Channel Surfing.
Go Ahead. Use Us.
May 07, 2008 | Remote Controls
Philps Universal cl034 needing codes
i need the tv code(toshiba tv) for my phillips universal remote control model CL034
Dec 28, 2007 | Philips RC2573 Remote Control
Need codes for a Sanyo TV
I have a 15-2147. The codes from solution 1 didn't work for my remote, so I used the codes listed on Radio Shack's page for the 15-2142. The first code worked. Those codes are: 0154, 1907
Aug 17, 2007 | Radio Shack (15-2147) Remote Control
Tv remote control not the right product #
dear sir, try to get more information because there is no sanyo RMT-U22C... try to look under the battry cover.. for more information to help you know what is your remoter ?
Jun 02, 2007 | Sanyo RCPLC8810 Remote Control
Remote Controls Logo
Top Sanyo Remote Controls Experts
alexander woolfolk
alexander woolfolk
Gareth Cockram
Gareth Cockram
Are you a Sanyo Remote Control Expert? Answer questions, earn points and help others
