Question about Sony KV-32S45 32" TV
Cannot power up my Sony Trinitron KV-34HS510.
Has blinking standby light and makes a noise when attempting to power up.
  • 1 more comment
  • hocemjr Dec 09, 2008
    Thanks for the help. I will post an update after I do your suggested checks.
  • Anonymous Jan 20, 2009
    i have the exact same problem and im vacumming it right now
  • frsfc45w Jan 20, 2009
    i have the exact same problem. im vacuming it right now
  • Sony Master
  • 5,568 Answers
makes a noise
This doesn't tell us much; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
Posted on Dec 09, 2008
What is wrong a Sony trinitron kb-34hs510 blinks 7 times has power but no sound and no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 17, 2014 | Sony FD Trinitron WEGA KV-34HS510 34" TV
The tv standby light blinks 7 times then repeats. What do I do?
Dear John,
Welcome to Fixya
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. I think it helps
Chandrashekhar
Dec 27, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Trinitron won't turn on
this is the (OVP) over voltage protection,the unit goes into standby mode,there is a problem in power supply circuit,you need a ohm meter ,check T603 & R672.......you can get parts at Encompass Disturbution #1-800-638-3328 hope this helps.good luck
Feb 15, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Apr 11, 2009 | Televison & Video
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony FD Trinitron WEGA KV-34HS510 ... does not power up.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.This may help the solution or let no what is wrong!!
  • Jan 16, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    I have a Sony Trinitron KV-34HS510 with a blinking standby light but I cannot turn on the TV. It sounds like it wants to power up but it won't. Is this a relay problem or a sensor problem and how do I fix...
    Please post the blink count of the standby light. That will indicate the circuit in which the problem was found that triggered the "protect" mode. Further details can be provided once that count is available.
    Thanks,
    Dan
    Dec 04, 2008 | Sony KV-32S45 32" TV
    Sony trineton KV-34HS510
    let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
    Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony KV-32S45 32" TV Logo
    136 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
