Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Thermal Expansion Bubble burst ... will Hitachi cover repair costs?
I found antifreeze on my main circuit board of my Hitachi 51F500. I thought one of my CRT's leaked but a tech was out today and it turns out that one of my Thermal Expansion Bubbles burst. Hitachi paid for the $99 trip charge for the tech to diagnose my problem. My question is, "... will Hitachi also cover all charges to repair the TV?" The tech said I will have to replace the circuit board also etc. Has anyone worked with Hitachi before? So far, they seem very accomodating. -- thanks.
  • 1,284 Answers
Re: Thermal Expansion Bubble burst ... will Hitachi cover...
It is actually an expnasion valve and try contacting Hitachi directly as they usually are pretty good about working with consumers. Although id the TV is out of warranty there is probably nothing they will do but, it doesn't hurt to try.
Posted on Feb 20, 2007
0 characters
3 Points
I am still having the blury wording on my HITACHI 51F500 the three focus buttons seem to do nothing when I turn them
If you turned the focus buttons (controls) you just made matters worse--if 3d etc the convergence circuit needs REPAIR which consists of replacement of the the two chips used.
May 18, 2012 | Hitachi Projection Televisions
Hi, i have 2003, 57 in" hitachi rear projection tv, model #57G500A. the problem is a thin wavy line across the top and bottom of the screen. could you tell me what would cause that.thank you for your...
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have 2 dead convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Mar 21, 2011 | Hitachi 51F500 51" Rear Projection...
Hitachi 51f500 wide screen hidef monitor,red green ghosting on right and left sides of screen
Ur tv convergence are dead.U know how to do soldering?U must replaced 2 STK convergence ICS and some or all it resistors.Tries websites Tv repair, to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
My Hitachi TV Model #51F500 is showing shadows and double lettering (in other words a terrible picture). Please help.
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
Nov 05, 2009 | Hitachi 51F500 51" Rear Projection...
Scratch Screen
Sorry about the late posting. The protective screen can be purchased from using the part number KR2074. This will cost $80.36 plus shipping. This should be a straightforward replacement. The instructions are included with the screen.
Hope this helps,
Oct 13, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 51f500 magic focus
convergance amp ic bad
Dec 12, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
Leaky CRT's
i would not repair unless you also replace any circxuit boards that the liquid fell on. although it is now water it will corrode the parts & will most likely cause further problems. the only way to ensure that future problems are not related to this is to replace the boards affected. good luck.
Feb 01, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
