Question about Kenmore 72602 Gas Dryer
No heat to dryer
I have a Kenmore gas dryer model number 110.97282100
my dad had it before me and he told me to see if it ignites or if i see a glow...and that there should be a little door that i open to see...well on the front of the dryer it says pilotless so what does that mean and what could be wrong with my dryer?? please help soon have a baby husband and a lil brother to do laundry for
thank you
  • ene62905 Dec 04, 2008
    it is old i'm pretty sure its made in 1992 because i had an eletric one just like it and the motor went bad so my husband was going to take the motor out of the gas one and put it in the electric one so i checked to make sure it was the same motor and it was then it said something about 1992......so it is pretty old...i just dont see anywhere i can find a glow
    Sergeant:
    Champion:
  • 291 Answers
It mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Posted on Dec 04, 2008
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
Kenmore gas dryer model number 111.76712693 no heat coil wont light up do you think its the igniter sabrefan29@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Kenmore Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
My gas dryer runs but no heat.
Most gas dryers use a surface-type ignitor, a ceramic element with traces that glow to ignite the gas and yours has failed. BTW, it's helpful to give model numbers so we don't have to guess.
Aug 27, 2009 | Kenmore Dryers
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
Dryer will heat up then gas shuts off and will not re-ignite.
That is a sign that the coils that open the gas valve have become weak. The one sitting toward the outside has a 3 wire connector and works with the igniter. When worn out they may open the gas valve for about 3 second or sometimes not at all.If you look inside the door and get me the model number I will get the part number for you. Some people sale a kit of 2 each. Let me know, Sea Breeze
May 22, 2009 | Kenmore Dryers
Start gas dryer heat will ignite after a couple minutes no heat
That is usually a sign that the gas solenoids are weakening. Sometimes for some dryers you can buy a pair. Don't know your complete model number.Thanks, Sea Breeze (Visit my site)
http://servicepartstec.blogspot.com/
Mar 23, 2009 | Kenmore Dryers
Gas dryer suddenly won't heat
There is an igniter that should create a spark. Can you see a spark at the pilot light area? Your orifices could be clogged or dirty. Check to see if the valves and burner area are free from debris.
Jan 20, 2009 | Kenmore 63942 Dryer
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Kenmore 72602 Gas Dryer Logo
382 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
