Question about Panasonic SC-HT740 System
Problems with panasonic sc-ht740 help!!!
OK I HAVE A PANASONIC SC-HT740, A HD CABLE BOX, AND A HDTV.MY PROBLEM IS I WANT MY HOME THEATER TO BE ABLE TO BROADCAST ALL MY TV SHOWS THROUGH IT. AND I JUST DONT KNOW HOW ELSE TO DO IT. I REALLY NEED SOMEONE WHO HAS ALREADY DONE IT WITH THIS PANASONIC SYSTEM. IDONT NEED SOMEONE TO SAY IT CANT BE DONE BECAUSE IVE READ THAT IT IS POSSIBLE. SO PLEASE IF YOU HAVE DONE THIS WITH THIS SYSTEM HELP ME WITH YOUR KNOWLEDGE. THANKS
  • rankindragon Mar 17, 2008
    I have the hdmi cable hooked up from dvd player to the tv, and two composite cable hooked up from the dvd player(in the Aux plugs) to the tv and also the red and white cables run from the tv audio out to the dvd audio in ports. When I punch aux I don't get anything, no tv channels no sound what do I do now. Thanks!!
Use both the HDMI ports from the DVD and Cable Box into your TV. 5.1 sound should then work if you press the AUX button. I have the same and that is how I set it up
Posted on Jan 09, 2008
Hi i was hooking up my panasonic home theater with the power on i heard a sound and the power came try power it up went on display f61 and then shut off what seem to be the problem model...
Never hook up theater units with the power on, you need to have the fuse replaced in your unit. You need a trained tech. for this electrical problem.
Oct 19, 2010 | Panasonic SC-HT740 System
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
SA-HT740 Broken gear
You probably can get the parts from Tritronics, but as far as I know, there aren't hard-copy manuals normally made for any of the newer products. The only paper available nowadays are the users manuals... The service manuals are on-line at Panasonic and available only to authorized repair centers. Sorry.
I'm curious - how in the heck did a gear break in the thing??? There's nothing strong enough in the drive system to do that (either the motors would sieze or belts slip).
Bugman Mark
Nov 01, 2008 | Panasonic SC-HT740 System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Surround sound
The t.v. broadcast will have to be in 5.1 for it to work, otherwise it will just be a 2 channel stereo mix.
Aug 06, 2008 | Panasonic SC-HT740 System
Connection problems
kristin
what you need to do is look at you HD DVR box and see if you have an "optical" port on the back then check and make sure your home theater box has an "optical" port. if they do all you have to do is go to radio shack and pick up an audio OPTICAL cable and go between your HD DVR and your home theater box.
May 04, 2008 | Audio Players & Recorders
Panasonic SC-HT740
In STOP (no disc)
mode, press STOP button
on the player , and 10
button on the remote
control unit.
Sep 19, 2007 | Panasonic SC-HT740 System
Panasonic SC-HT740 System Logo
232 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
