Question about Vivitar ViviCam 5100 Digital Camera
Video doesn't work
When I press the button for video, it records for maybe 2 seconds, sometimes even 4 seconds, then stops. Then I can't turn it off, I have to remove the batteries to turn it off. How do I get the video function to work?
It did this to me before I got a memory card put into it. you can get and use any SD memory stick at walmart I got 2 sticks of 1GB for $20 there. The place you put the stick in is a slit inside the battery case above the batteries...it took me a long time to find it lol!
Posted on Sep 07, 2007
Cannot send video via text from samsung galaxy note 2 to samsung galaxy note 1
There might be some software differences between the Note 2 and Note 1.
MIGHT be, it could also be a glitch or maybe the mobile network (3G) wasn't turned on, and as far as I know, you have to press "download" on the message you get when someone tries to send you and MMS (picture/video).
If neither of the above works, it could be a glitch, or in worst case, a software difference that makes the phone unable to see/download the MMS.
Dec 07, 2012 | Samsung Galaxy Note II LTE N7105 4G...
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Lost Instructions for Little Tikes My Real Digital Video Camera
I also recieved a prompt reply, with attachment - here's paste of the text only:
INTRODUCTION
CONTENTS
Item no.: 608728
Ages 3+
ADULT BATTERY INSTALLATION REQUIRED
Get ready to make your own movies with the Little Tikes™ My Real Digital Video Camera! This
durable and fun camera is easy to use and really records video and takes pictures, even up to a
depth of three feet under water!
Illustrations may vary from actual contents.
IMPORTANT: An adult must remove and discard the plastic label from the LCD Display before use.
• Little Tikes™ My Real Digital Video Camera
a. Microphone
b. LED Light
c. Lens
d. Power Button/Mode Selector
e. Mode Display
f. Edit Button/Edit Mode
g. Trash Button/Delete Mode
h. Volume Selector
i. Zoom Button
j. Record/Confirm Button
k. Speaker
l. Left Button
m. Right Button
n. LCD Display
o. USB Port
p. TV Out Port
q. SD Card Slot
r. TV Out Cable
s. USB Cable
t. Adjustable Neck Strap
u. Carrying Case
WARNING
Constant, competent adult supervision
is required at ALL TIMES when small
children are near or in water.
m
g
t k
a b
c
j
d f i
hl
e
p q o
(inside the cover)
n
s
r
u
BEFORE YOU BEGIN
Battery Installation
An adult must install batteries. Here’s how:
1. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the camera.
2. Remove the screw and Battery Compartment Cover .
3. Install two (2) AA alkaline batteries (not included) making sure the (+) and (-) ends face the
proper direction as indicated inside the battery compartment.
4. Replace the Battery Compartment Cover and tighten the screw.
5. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal.
Optional SD Card
Your Camera will hold approximately 10 minutes of video or 250-1000 still photos. Since portions
of the free memory space indicated in the Menu Mode are used to store the photo program, the
available space for storing photos etc., may be reduced. These numbers may also vary depending
upon the camera mode settings and the images being captured. To enlarge the memory, an
SD card (not included) may be purchased from your local camera store. To install the card an
adult must:
1. Make certain the camera is turned OFF.
2. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the Camera.
3. Slide the SD card (not included) into the slot until it clicks. (DO NOT force the SD card. If you
feel resistance, remove the card, make sure it is facing the correct direction, and try installing
again).
NOTE: SD card label must face toward the Camera Viewfinder and the edge of the card with the
copper contacts must be inserted first.
4. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal to keep
water from entering the card slot.
IMPORTANT NOTES:
• If the Watertight Cover is not completely sealed, water may enter the compartment causing
irreparable damage to the camera.
• USE CAMERA IN FRESH WATER ONLY. DO NOT USE IN SALT WATER.
• Using the Camera at a depth of more than 3 feet is not recommended.
TIP: Keep an eye on your battery level by checking the Battery Gauge in the top-right corner of
your screen. If the Gauge is red, new alkaline batteries need to be installed.
1.5V AA/LR06
1.5V AA/LR06
unscrew
TV Out Port
USB Port
SD Card Slot
unscrew
unscrew
1.5V AA/LR06
1.5V AA/LR06
Battery
Compartment
Cover
Watertight
Cover
IMPORTANT: To save your photos and videos directly to an SD card, you must go to the Storage
Section of the Menu Mode (see Page 5) and change the setting from internal memory to external
memory.
NOTE: Never insert anything other than an SD card into the card slot as doing so may damage the
camera and the SD card. To remove the card, press in on it and it will pop out.
IMPORTANT: Should water or any foreign object get into the Battery Compartment or the Card
Slot, turn the camera off immediately, remove the card and/or batteries, and allow the camera to
dry out completely before attempting to use again.
QUICK START
ATTACHING THE NECK STRAP
An adult must attach the Neck Strap. Here’s how:
• Place the clip on the end of the Neck Strap into the
opening in the connector which is attached to the camera
and press firmly until it clicks into place. (Fig. A)
• Repeat the instructions above to attach the remaining
end of the strap. (To detach the Neck Strap squeeze the
clip edges and pull apart.)
• Adjust the length of the Strap by using the plastic buckle
located along the strap.
NOTE: To attach or detach camera portion of connector,
see Fig. B.
CAUTION - DETACH NECK STRAP FROM CAMERA
BEFORE ENTERING WATER.
CAMERA MODES
VIDEO MODE
In this mode the Viewfinder will show what the camera sees in real time.
• Set up your shot in the Viewfinder then press and release Record to take a video.
NOTE: A red “RC” icon will appear in the top-left corner of the screen, and the elapsed time will
appear in the lower right corner.
• To stop recording and store what you have recorded, press the Record button again. The screen
will switch to the beginning of the film you just recorded with a big red Play arrow in the middle.
• Press the Record Button and the video will play back.
• Press the Left Button (or wait 5 seconds) and the camera will go back to the live image.
TIP: You can zoom the camera in and out by pressing the Zoom buttons! The Zoom Indicator on
the right side of the screen will tell you how far you are zoomed in or out!
NOTE: There is no zoom function in 640 X 480 video mode.
Video Mode
Still Picture Mode
Playback Mode
Fig. A Fig. B
ADDING SOUND TO YOUR VIDEO
• Before recording, press the Edit Button. You will see Sound and Image icons. (Fig. 5)
• Use the Left or Right Buttons to select Sound then press Record to confirm.
• Press the Left or Right Button again to hear the available sounds. (Fig.6) Stop at the one you
like, then press Record to add it to your video. The camera will then return to the live image.
Press Record to record your video with the sound included. Press Record again to stop
recording. (Press edit to exit edit mode.)
NOTE: Turn the Volume up high so the microphone can hear and record the sound!
ADDING IMAGES TO YOUR VIDEO
• Use the Left or Right Buttons to select your choice then press Record to confirm.
• Press the Left or Right Buttons to see the available images. (Fig.7) Stop at the one you like,
then press Record to add it to your video. The camera will then return to the live image with
your selected graphic. Press record to record your video with the image! Press Record again to
stop recording. (Press edit to exit edit mode.)
IMPORTANT - images on videos will only appear when viewed on camera viewfinder or on
TV screen.
Fig. 5 Fig. 7
L R
Fig. 6
L R
Construction
TURNING THE CAMERA ON
Once an adult has installed the batteries:
• Press and hold the Power button for 2 seconds. The Little Tikes™ logo will appear on the screen.
• Once the logo disappears the camera will automatically be set to Video Mode.
NOTE: To change modes, press and release the Power button. To turn the camera off, hold down
IMPORTANT: Before making videos or taking pictures, see Page 4 (MENU MODE) to set picture
quality. Also, camera must be at least 2 feet away from subject for best focus.
1 2 3
Jan 03, 2009 | Little Tikes My Real All-Ter Digital Video...
Canon Powershot A630 video recording issue
This could be your memory card going bad. Recommend trying a "low level" format of the card to see if that jump starts it. First download all images and videos as the format will erase them from the card. Next press the menu button and select the settings (tools) menu. Go down to the format option, and press the "Func Set" button. Make sure "Low Level" format option is checked before selecting OK. After you format the card, try the video to see if the problem is fixed. If the above didn't help, recommend trying a different card.
May 27, 2008 | Canon PowerShot A630 Digital Camera
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
Pv-dv53d
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Oct 11, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
No Sound when Capturing
ah. This happens to me sometimes. Well, for some reason it always works when i first open USB streaming tool( this program is not for recording)use the program to edit the video, like to fix brightness etc. Then open capturing tool. This is what you use to capture the video to your computer. What i do is to press the play button in the program, not the capture button. The video on the camcorder and the video on your screen should start playing. I do this just to test the video if its gonna have sound or not. Then you rewind the video by pressing the rewind button in the program. After that press the capture button. Sometimes it records and you don't hear the sound on the computer, I'm not sure but maybe after its captured into the computer, the video will have sound. If you do record, but with no sound, record about a minute and then stop it. Go to where you saved the video and check if there is any sound. Hope this helps you. Sorry if it's kinda confusing because i don' use the program no more. I use a DVD recorder which you connect your camcorder to the DVD player and it burns the video directly to a DVD. Its much mroe easier but you can't play around with it on the computer.
Jan 12, 2007 | Sony Handycam DCR-HC32 Mini DV Digital...
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Vivitar ViviCam 5100 Digital Camera Logo
20 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
