Question about Casio Exilim EX-Z57 Digital Camera
My camera is suddenly displaying a message that states that my card is locked, can you help me unlock it?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Hp photo smart camera has message in viewer saying card locked. what do i do?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 15, 2014 | HP Photosmart M415 Digital Camera
I have a Kodak Easyshare V1233. I am getting am message stating Memory card is locked. How can I fix this?
Hi, take memory card out of camera,
there will be a little slider on the side of the memory card, slide it to unlock memory card. slide it back to lock.
Hope this helps
Mar 08, 2012 | Kodak EasyShare V1233 Digital Camera
How to fix memory card error problem and card locked ,fix is in the camera.
Is it physically stuck in the camera or there is a message stating that the card is locked?
A locked SD card can be unlocked by sliding the tab on the long edge to the opposite (unlocked) position as shown below:
Nov 22, 2011 | Canon Cameras
My memory card in my canon camera suddenly won't let me take or delete pictures because it says card locked. - have been using it without a problem but then today it suddenly said "card...
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards.If youare getting a memory card locked message then check this out.
How to UnlockSD Cardheatman101
Aug 04, 2011 | Cameras
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
I have a message on my digimax A400 screen stating CARD LOCKED can u help plse?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 26, 2011 | Samsung Digimax A400 Digital Camera
Memory card is write protected. how do i reset
Hello and Welcome to Fixya!
Turn off the Device, put the Card out and see there will be a small switch/latch on some site of the card, and there will be stated the Lock/unlock state, if it is locked. change the position according to the description.
I'm attaching photos for your convince.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
Aug 05, 2010 | Olympus Camedia C-350 Digital Camera
When I turn on the camera an air message states "CARD IS LOCKED"
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 15, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
The card on my Photosmart HP E427 appears to be locked all of the sudden. I get a message that says "cards is locked" - What caused this and how do I unlock the card?
Mar 17, 2009 | HP PhotoSmart M437 Digital Camera
Memory card error (states memory card locked) not locked
Remove the card and look for a tiny slide switch on the side of the card. Slide this switch to the other "unlocked" position. Reinsert the card and try it out.
Jan 11, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Casio Exilim EX-Z57 Digital Camera Logo
21 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
