Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Double image in bright blue with philips model 55pw9363/17f
The picture is fine but there is a bright outline around. sometimes its worse then others depending on what you are watching. i was told it had something to do with a "blue conversion" and two seperate components had to be changed at the cost of app. $400. there is no manuel with the t.v. and information is hard to find or even get. Please help.
  • Grizzlemail Dec 17, 2008
    same problem, blue shadow, less on the left, and increasing as it goes to the right of the screen.  I was told that cleaning the lenses would help this problem, just looking up what philips would recommend for cleaning methods.
  • Philips Master
  • 3,459 Answers
You may have 1 of two problems.
1) Convergence Chips are failing - Using your original remote goto the "convergence" screen.
Try to adjust the red - UP - DOWN - LEFT - RIGHT
Next try to adjust the blue - UP - DOWN - LEFT - RIGHT
If you can move both colors in all directions you do not have a convergence issue.
If you can't move one or more colors in one or more directions the convergence chips are defective and need to be replaced.
If your convergence chips test out ok the most likely problem is......
2) CRT Coolant is cloudy  - The bright outline you described is one common symptom. Other symptoms include dull images, red or orange tint, halo around images.
If you goto the site www.TvRepairKits.com - and click on "Tips" - you will find more detailed instructions on how to check the convergence.
Posted on Dec 22, 2008
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
Green edge around images (outline)
my 2002 sony wide screen projection tv has menu and pictures when turned on first thing in the morning?
Jan 30, 2010 | Mitsubishi WS-55905 55" Rear Projection...
Blue outline around images on screen and also on menu yellow offset. picture was fine. I have tried convergence and did not help
Have the convergence IC's replaced. Only one has failed but have both IC's changed as the other is not far behind..
Thx please leave comment
Oct 08, 2009 | Televison & Video
Blue outline around images on tv
Sounds like a convergence problem. I can tell you that the site that Jean posted will not fix this problem and could even make things worse. That site pertains to a specific problem that is common in some Sony sets and should not be used to try to fix any other issue.
Please keep in mind many things can go wrong with TV sets and you should really do a lot of research before attempting any adjustment and or repair. There are high voltages present and they can reside even when the set is unplugged.
Jan 29, 2009 | Televison & Video
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
2001 Philips 43P8341Blue outlines on images
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 10, 2008 | Philips 43P8341 43" Rear Projection...
Philips magnavox 9p6040 projection tv
no the coolant needs to filled all the way, you did right. try focusing the blue tube with the blue focus control, and you may have to run a multi point convergence adjustment through the picture settings menu.
Jun 20, 2008 | Philips 9P5534C 55" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Picture Pulsating
I have the same set. I solved this by turning off the dynamic contrast or adjusting the contrast and brightness settings down.
Dec 30, 2006 | Philips 60PP9202 60" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
345 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
