Question about Panasonic NV-SJ205 VHS VCR
Panasonic nv-sv120 power shut down
Noticed my panasonic video (nv-sv120) player was showing all its display characters on the units small screen one day. I attempted to put in a video but it would not take it in. Then it suddenly shut down all power and it has not worked since. Could this just be a power pack failiure in the unit and where could i source a new one if so. Please also note that the top of the video player is completely covered with other electrical devices (stereo, speaker! and digi box) which i wonder wether cased the unit to fail. Plug fuse is ok.
  • 1 more comment
  • nickgrimshaw Feb 12, 2008
    I had the same problem with a NV-SV120 Video recorder that was 13 months old and had only ever been used about half a dozen times (probably about 20 hours of recording in total) Panasonic did not want to know because it was out of its gaurantee so feel a bit cheesed off about them. I had similar prolems with a DMR E55 purchased from them as well. Looks like this one is on it's way to the scrap heap. Your fix for the DMR E55 worked perfectly - thanks.
    Checked the fuse and this was sound and power appears to be circulating around the board. However, to the R/H front side of the board (near the eject button there was discolouration as if the board was getting hot.
  • Anonymous Mar 04, 2008
    Had the same fault on a NV-SV120, replaced the blown capacitor (12V 1000uF) and hey ho perfect again, excellent picture on this machine. Very good for playing those cheap videos all the charity shops are selling.
  • soomg Mar 16, 2008
    I have the same problem but I can't find any 1000 uF capacitor. I have 2x680 uF instead that look strange. But I can't figure out how to access the PCB for capacitor replacement.
Regarding panasonic nv-sv120 power shut down: I replaced C1250 (680 uF/25V) and C1260 (1200 uF/10V) and after that is was working perfaect again.
Posted on Mar 17, 2008
C45 on the psu SECTION I AGREE
Posted on Aug 08, 2007
I'v had exactly the same problem with my NV-SV120. After replacing C1250 and C1260 (1000µF-16v-105°) ... It worked again perfectly.
Posted on Jan 02, 2010
Absolute rubbish. Much more likely to be c45 on the power supply board
Posted on Jul 25, 2007
    Novelist:
    Champion:
  • 275 Answers
There cannot be any reason pin pointed for a Electronics Equipment failure. But from your brief description, it seems that there has been an Electrical surge, which has probably blown the Fuse in the Power supply of the VCR. The various extra equipments placed on the machine are not in any way responsible. But, it is not adviseable to place these additional equipment on top of the machine. Remove them ASAP!
Posted on Feb 07, 2007
Lcd screen monitor
its may be LCD flex damage
http://www.ebay.com.au/itm/NEW-LCD-Flex-Cable-Repair-Parts-Panasonic-NV-MD10000-MD10000-F0081-/151132846898?pt=UK_Replacement_Parts_Digital_Camera_Parts&hash=item2330383b32
Mar 14, 2014 | Panasonic NV-MD10000 Camcorder
No memory card for the Panasonic NV-GS10 camcorder...
The NV-GS10 uses MiniDV tapes. You should be able to buy these at just about any camera, department, or electronics store.
Feb 19, 2012 | Panasonic NV-GS10 Mini DV Digital...
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
Unit power LED blinks then shuts down
Blew out the cassette mechanism and cleaned also. Disassembled and re-seated all connectors and ribbon cables. Blew out lens assembly.
Dec 30, 2008 | Panasonic NV-DS65 Mini DV Digital...
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Service manual for Panasonic Handycam NV GS15
I fixed 2 cameras with same problem "Push Reset Switch"
Removed small foreign plastic object which was jamming mechanism without stripping.
In both cases a very tiny piece of one of the broken plastic 'catch' of the door was the problem.
Turn unit upside down and give it a good shake-up and it will drop off & problem solved.
Hope this helps.
Seedata
Feb 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Camera turns off
Reset the camera. This may fix it. Is there a reset button on it? I have a GS-120 and I have to hit the reset button when the red light is flashing.
Jan 22, 2007 | Panasonic NV-DS15EN Mini DV Digital...
Panasonic NV-SJ205 VHS VCR Logo
651 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
