Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Model EL7020 will not stay running!
The machine has a new bag, the filters new, machine is only 1 year old. The machine starts but shuts off just after a few seconds. The three blue lights on top of the machine flash from MIN to AUTO to MAX and cycle. The filter light and bag light come on right after it starts and maybe 3 seconds running it shuts off. Simple fix I hope. Just found out today this ain't no Electrolux.. Paid $499 at Lowe's. We had an Electrolux for 30 years and gave it to the youngest boy. 5 Years ago and it runs like new. Never had but one problem, it needed carbon brushes for the motor. I hate this thing.
  • 73 Answers
Try turning the knob on top of the machine all the way to the right and try it again
Posted on Aug 28, 2009
Electrolux el 7020 Canister Vacuum shuts of continuously do i need to Change the Carbon Brushes
How old? If fairly new you should not need brushes, bad brushes would probably not allow the vacuum to run at all. Last time you changed filter? Sounds like the cover to the filter is not closing well enough. There's also possibility you have a clog in the wand or hose.
Mar 05, 2015 | Electrolux EL7020 Bagged Canister Vacuum
My dyson shuts off after just a few seconds of run time.
Make sure the charger is operating. Then if it is, look at a failed battery.
Jan 13, 2015 | Dyson DC16 Root 6 Bagless Handheld...
Electrolux 2100 vacuum
Electrolux has had this issue across all tank machines for years and it has to do with the orientation of the bag. The bags are model specific and must be installed properly. Consult your manual for the proper filter bags and how to install them. The door on the bag will pop open and shut down the machine if the bags are not the proper ones and don't fit precisely. It is supposed to be a safety feature but it annoys the devil out of people and has for years. Their machines are very powerful and well made, but if the bag does not seal properly around the hose inlet or the gasket around the door and bag chamber leak, then you will have this happen.
Nov 20, 2017 | Vacuums
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
Nov 11, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My vaccum shut off and will not start up.
Does it try? Or is it just totally dead, doesn't even grunt when prodded?
Some will shut off if overheated, and will later start just fine.
Some will shut off if an internal filter gets too clogged and the motor is straining too hard. Open it and clean/ replace any internal filters - often it's just a piece of mesh/sponge in a frame near the motor housing, inside the machine. Remove, rinse, shake off any water, re-insert. Try to start.
If vacuum is the bag style, is there a lever/switch inside that gets pressed when the bag is too full?
For a removable bag, try removing the bag and see if the machine will run for a couple of seconds without the bag present. Of course it might have a sensor and refuse to run if _no_ bag is found... but at least if it did try to run, that would give you a clue.
If it's the kind that has a rug-beater/spinning-brush cleaning head, is there a small (usually red) button possibly labeled "Reset"? What happens if you press that? If no beater head is involved, try looking all over the outside of the machine - and then start opening cover(s) and looking inside for anything like a reset button. Or a fuse. Can't really be more specific. Not a real expert... just spent hours poking around inside my own vacuum for a different problem.
- Inspector Dryfish
Jul 22, 2009 | Euro-Pro NV31 Infinity Vacuum
Aerus Model 152C- vacuum doesn't run
it probably does think you have a full bag.make sure you have it cleaned out and has a bag in there or it might be the sensor for the vacuum and is not working properly. contact your nearest electrolux vac store.or you are not using proper bags.
Jun 28, 2009 | Electrolux Vacuums
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
449 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
