Question about Frigidaire FRS26R4A Side by Side Refrigerator
I have a Frigidaire Refrigerator (side by side) - and both sides are not working. We noticed the Defroster-Heater was cracked and when we connected the cracked area the fan would turn on. We just replaced the defroster-heater, but now nothing turns on. Can you please tell me what I should check next.
    Novelist:
  • 161 Answers
Check the defrost timer, it may be stuck in the defrost mode. In defrost mode the heater will not come on unless the thermo disc is cold. This disc is attached to the coils close to where they come into the freezer.
Posted on Dec 17, 2008
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Frigidaire Refridgerator not cooling. Worked for about 2 weeks after replacing defroster
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute
Jun 01, 2012 | Frigidaire Refrigerators
My freezer won't freeze, but the refrigerator section is OK. I clean the condenser coil, check defroster heater and timer it seems that its defrosting the evaporator coil every 8 hrs.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer is cold but not freezing, refrigerator is not cold
your defroster heating element behind the frosted panel is either open(bad) or the defrost heater control in the refrigerator compartment is defective
Jul 13, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Fan in freezer side runs almost all the time,coils are freezing up,timmer is working, allready changed defrost timmer still freezing over.freezer side is working fine. need help........
There is a problem with the defroster circuit. You already mentioned the timer was replaced. You need to consult your manual for a diagram ( or search at applianceparts.com) to see where the defroster thermostat, thermal fuse, and defroster heater itself are located at, or where the wiring is run.
I suspect your thermal fuse / defroster thermostat has failed.
Jun 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
How do I check if defroster heater is bad? On a Frigidare Side by side Mod FRS26ZSE?
if the defrost heater is gone you will have a large frost build up in the back of the freezer side.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Defroster drain leaks into the main compartment
The drain hole is plugged. Probably with ice now. Needs to be fully defrosted with a heat gun or hairdryer, be sure drain is free by pouring hot water into it and seeing it get to the pan below the machine. If this persists you need to troubleshoot the automatic defrost circuit. Could be bad defrost timer.
Sep 01, 2009 | Frigidaire FRS26H5AS Side by Side...
Front Center wall getting hot to the touch On Frigidaire side By
Normal operation to reduce outside condensation.
Could get up to 120 degrees.
Jul 04, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
248 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
