Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Computers do not recognize Maxtor
My one touch maxtor worked last week, but doesn't this week.
I plugged it in to my laptop USB ports, and to 2 different computers. I tried another persons cables from a like maxtor and it still didn't work. I plugged her maxtor into my laptop and her unit worked.
When I plug it in to any computer the light will go on, but there is not indication that the computers are seeing any connection in "my computer"
What can I do? Can I get the information off the maxtor in other way.
Nano Farabaugh
  • 2 more comments
  • Anonymous Dec 28, 2008
    We have the same problem! Please let us know if you have found a solution!
    Thank you!
  • fotomandave Dec 29, 2008
    I am having the exact same problem....
  • a_6_guner Dec 30, 2008
    i have the same problem
  • bill404 Jan 02, 2009
    same ting
This isn't a solution, but will give you more information about whether you can recover the data. If your computer recognizes the drive when you insert it, but doesn't assign it a letter, you can probably recover much of the data.
For XP: Click on "Start"-"Settings"-"Control Panel", and select "Administrative Tools". If you don't have that menu, there are other ways to get into the control panel, depending on how you've configured your OS.
Click on "Computer Management" (on the right window), then "Disk Management" (on the right again). This shows a picture of each of the hard drives on your system. The "Volume" shows the letter assigned. If you unplug the hard drive, and then plug it back it, you can easily tell which volume is being added or removed.
If you can right click on the volume, it may be a simple matter of running "checkdisk" to fix any errors (click properties, and see if that is an option in the "Tools" tab). If all the options are disabled, the drive has been corrupted. However, you may still be able to recover the data with a data recovery program (I have R-Studio, but there are a lot of others out there). If the drive doesn't show up at all, you'll probably need a professional.
Note: If you have a lot of drives, you may just need to free up a drive letter to be able to see the drive. You can right click, and if "Change drive letter/path" is enabled, try that.
Posted on Jan 03, 2009
My Maxtor One Touch 3 (300gb) external hard drive is not being recognized by my computer (or my laptop). I plug it in to the back usb port, turn the Maxtor on, then the light turns on, but the computer is...
Hi Jane,
If you are using Windows as an operation system, you can try to install the HDD manually
Click on the Start button
Right click on My Computer
click on properties at the bottom
look for the Hardware tab and click on it
look for the Device Manager button and click
look for Action in the top menu
then scan for new hardware
If this does not work, look on the Device Manager screen and you will see + Disk Drives
click on the + and it will list the drives that it sees
if you see the external HDD uninstall it and reboot
Hope this helps
Dec 22, 2010 | Computers & Internet
Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
Jan 05, 2010 | Maxtor OneTouch II external hard drive...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
6-29-2008 I have a Maxtor One Touch 4 Mini that I use to back up files on my desk top and also want to use it to transfer the same files back and forth with my laptop. Both the Desk Top and the Lap...
After following the on-line instructions I replaced the USB cable that came with the Maxtor with a difrent one and now the drive works as it should. I do not know what the problem is with the original USB cable.
Thanks for the follow-up
Glenn Alford
gamafay@aol.com
Jun 29, 2008 | Computers & Internet
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor one touch iii not recognized
Does Windows recognize that there is anything plugged in at all?
If not it could be your USB interface (on the Maxtor) is shot.
Nov 26, 2007 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
65 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
