Hot water heater
I have a new forty gallon electric water heater and we can only get about twenty gallons of hot water at one time
  • 50 Answers
U might have the temperature turned down to low. check the temperature. u might have to just turn it up
Posted on Dec 04, 2008
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Is a 80 gallon hot water heater legal for a 7 apt. building?
You probably need commercial 150gallon gas water heater.
Or three 80 gallon tanks, depending on number of people.
80 gallon residential gas heater is rated for low-demand 6-8 person household.
80 gallon residential electric is rated for low-demand 5 person household
80 gallon is not correct for 14-28 people in 7 apartments
http://waterheatertimer.org/Whatsize2.html
http://waterheatertimer.org/Two-water-heaters.html
Call local plumber, or local code department.
Apr 10, 2013 | Water Heaters
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
We have a reliance 606 50 gallon electric water heater. recently we noticed it has an internal leak. I removed the top and removed some of the insulation. the pipe fittings are dry but when you put water...
I wrote a page on leaking water heaters.
With a checklist.
It sounds like you've done quite a bit already.
The element can leak around the gasket.
The TP valve can leak where it screws into side of tank.
Otherwise a leak on side of tank sounds like the tank is rusted through and needs to be replaced.
You should turn off electricity and water to the tank, and open tub valve on hot side to relieve pressure so the tank will not rupture.
Then you can limp along with a failed water heater by turning the water and electricity on only when hot water is needed.
This will buy you time until a new heater is installed.
A typical electric water heater produces 21 gallons of hot water per hour.
A shower uses 6-9 gallon of hot water, so heater only needs to be turned on 20-30 minutes for a shower, more if the incoming water is very cold.
To economize with your next heater, you might read the following two pages:
Nov 08, 2010 | RELIANCE ELECTRIC WATER HEATER
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
Sep 29, 2010 | Paragon 8145-20 Defrost Timer
New hot water heater cause smelly hot water.
U can clorinate ur water heater 1 gallon will do it. But you should try changing the anode rod(to aluminum) or removing it first followed by a complete drain, purge and refill.
Mar 29, 2010 | Water Heaters
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
