Question about LG WM1812C Front Load Washer
Front load lg
The drum in my front loader has began to make a noise and is very stiff to turn when empty.
CALL LG AND TALK TO TECH SUPPORT THEY MIGHT BE ABLE TO HELP YOU ON LINE. SOMETIMES THE RUBBER AROUND THE DOOR THAT IS HELD BY A SPRING COMES UNDONE AND HENCE GETS CAUGHT BETWEEN THE DRUM AND THE CABINET. CHECK THAT & GOOD LUCK
Posted on Feb 21, 2007
Bearingd gone my advise to buy new machine appliance doctor
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
My front loader washing machine is making a kind of squeaky noise when it spins. The washer is working..but wondering what it could be.
If the noise comes from the drum rather than the back of the machine it could be the drum bearings on their way out.
With the drum empty take hold of the top and bottom of the drum edge (from inside the drum). Gently try to lift and lower the drum, you may hear a slight knock - that's the bearings failing. Water enventually gets past the seal on the bearing and degergent in the water dissolves the grease in the bearing, causing it to fail.
Sep 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius drum makes a noise and is stiff at one point
You take the top off. A couple of screws on the back of the unit, then the top slides off backwards
Sep 07, 2008 | Hotpoint Aquarius WD63 Front Load...
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
Drum is stiff to turn
clothes caught between inner and outer Drum, you have to get it out !good luck eire.
Nov 18, 2007 | Zanussi FLE1416W Front Load Washer
LG WM1812C Front Load Washer Logo
102 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
