My televisions screen is split. The right half has a picture the left has coloured lines. Sometimes i have a full screen and then it goes back to half. The tv is a Optima HD plasma.
  • 2 more comments
  • eddie_dhu Dec 04, 2008
    There are many cables on the set which one should ilook for. Also where would the sus cards be located.
    This solution does,nt help at all. What is the x buffer board and where is it and the main digital control board located. The first solution i received indicated loose cables or faulty sustainer cards. I asked what is a sustainer card and where is it located.
    The model no is PPMA42HD10. The serial no is P6B562CO0286
    I would have liked to be dealing with the same problem solver all the time as dealing with a different one each time i answer your question is getting very confusing and getting me nowhere.
  • 934 Answers
Need the model number for a better understanding of how that unit is put together (circuit design). Sounds like a dm board problem or Y-sus failure.
Bill
Posted on Dec 04, 2008
    President:
  • 2,110 Answers
It seems to be some problem with your circuit ...so it is better u take it to nearest service center...
  • 4,806 Answers
Whats the model number please
    President:
  • 2,267 Answers
This failure could be due to a loose connection between the X buffer board and the main digital controller board. This failure might not be a DIY or if your plasma is less then a year old, still under manufacturers warranty.
  • 19,396 Answers
It can be one of the sustain cards starting to go or a defective cable.
The sus cards should be tested and eventually replaced.
  • Ginko
    Ginko Dec 04, 2008
    Sorry about late replay, but I am located in a different time zone, and I went offline shortly after my first answer.
    If "The right half has a picture the left has coloured lines.", than that is not a setting problem, that means that the TV has a fault.
    If the image is also dimmer than normal, then it is for sure the Sus board that has a blown fuse and must be replaced (fuse indicates board is defective).
    If you get vertical band on a portion of the screen this can also be because of one of the ribbon cables that connect to the screen.
    This cables have a built in chip technology, and when the chip is fried you get vertical bands starting from where the cable hooks up.
    To find out the technician must remove the metal bracket and cable from the connector and read impedance on the resistors located on the cable.
    On many models there is also a board called lower buffer , when that goes faulty you also get a verical band , or part of the screen black, or covered in lines, depending on the fault.
    The most common fault of this kind is a defective ribbon cable (there are several of them) with built in chip technology.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Without a specific model to work on, let's try this:
Pls check if you have this feature, PIP (picture in picture) or Split Screen, if yes, then disable. It normally should be a button by itself on the remote or under Menu/Settings. Additionally, pls check if such a button is available on the front panel control and flick on it, this is in case the button is stuck or intermittently contacting on its own due to sound vibration.
In the event that there is no such feature or the feature is already disabled, then conclusion would be that the internal electronics/logic circuitry controlling this feature is faulty and switching on by itself intermittently. The unit has to be opened up. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. If the unit is still under warranty, demand replacement or repair.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
I cant get it to work on full screen
I am having this same problem as this one above (62HM95). The issue I'm having is that it will also not work full screen. I selected the 'Split' option on the remote and the picture on the left is fine... absolutely clean and perfect, with audio. The picture on the right is completely distorted in very strange colors (mostly constant variations of purple), with audio as well. You should note, that the same video information was feed into different imputes to select for the split. In other words, I feed the cable stream into the TV using the component video (Y B R) as well as the coaxial cable and selected both options for the purposes of displaying the same information side-by-side. On screen I selected video option four (4 for color stream HD) and option (0 for cable/antenna). If I highlight either side and select one of them (4 or 0) the screen goes full screen and I see nothing but one solid color of purple. I've researched the purple and they call it 'Electric Purple'. That is all I see... just the solid purple, with the audio. What I have also noticed is that, If toggle between imputes while in the full screen option and come back to either option (4 or 0) the image plays/appears OK for about 2 seconds then goes back to solid purple. I just can't understand why this is happening especially when the on-screen menu displays perfectly fine. I cannot enjoy this TV by only watching half of it in split mode. Besides the multiple replacement bulbs I've had to buy I've completely had it with this TV
May 29, 2012 | Toshiba 62HM95 62" HDTV
Samsung le26r51bd picture loss.
it is problem your tv high voltage (EHT) not properly supply or creats high voltage
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
WD-52525 split screen
what are you using as input? On this set only digital channels can be the main picture. You can try the exch button to see if it comes back right also.
Aug 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Split colors on screen
Replace the two convergence Ics they are STK392-110 if your model is the 53FDX20B you can get replacement Ics with installation instructions at the following link.
http://servicemanuals.vstore.ca/
May 11, 2009 | Hitachi 53FDX20B 53" Rear Projection...
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
51F510 Screen is split in two
requires service, horizontal fold over and possible other problems to come .
Sep 13, 2007 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
