Question about HP Photosmart C5180 All-In-One InkJet Printer
HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I have had the Hp Photosmart D7360 for about 3 months and printed approx 4 things from it mainly photos, the ink cartridges are full, I have taken them out and shaken them and replaced back into the printer but no success message "Ink System Failure Oxc18a0001" Are you able to help.
Thanks
  • 2 more comments
  • 3 Leg Dog Dec 11, 2008
    I have the same problem. I printed about 10 pictures when I first got it. I let it sit about a year and when I tried to use it again I got that $%^ message.
  • Anonymous Jan 11, 2009
    D7360 Ink System Failure
  • gwen1234 Jan 19, 2009
    HP Photosmart 7360 - Ink System Failure Oxc19ac008. HP tech support was not helpful but did want to charge quite a bit. Unplugged it, removed cartridges, etc. - still doesn't work. Any suggestions would be appreciated.
  • Anonymous Mar 12, 2014
    hp D7360 ink system failure error
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
  • henrik349
    henrik349 Jun 25, 2012
    It worked like a charm! But saying it was hard getting the cover off is an gross understatement!
    It could have easily gone wrong, but the alternative was a new printer anyhow so I'm happy it worked.
Solution about ink system failure 0xc18a0001
Posted on Dec 04, 2008
  • 3 Answers
Found this on another site - it worked for the 7280 so will probably work for this one also:
1. Press and hold the '*' key on the key pad, then press the '#' key and release them both.
2. Enter '123' to enter maintenance mode.
3. Press the right arrow (beside the OK button) until System Configuration menu appears on panel.
4. Press OK two times to clear the error condition, then press "Cancel" until you are back at the top menu.
5. Power off and back on.
Note that I got one further error message, but restarting the printer again resolved it.
Posted on May 20, 2009
  • Pam Duckett Nov 06, 2011
    This worked! thank you
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
What to do hp photosmart c1580 series ink system
hat to do hp photosmart c1580 series ink system failure Oxc18a0001
May 01, 2010 | HP Photosmart C6280 Printer
HP Photosmart All in One error message Ink System failure -Oxc18a0001
There are N no of steps to be done so i am pasting the HP URL ,please follow it and u will get to some kind of solution in the end or u might have to replace the print head .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
All the Best
Feb 17, 2010 | HP Photosmart C5180 All-In-One InkJet...
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
please reinstall the drivers
thanks for your question
May 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
2,638 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
