Question about Panasonic MC-V7720 Bagless Upright Vacuum
Dirt is not going into dirt chamber.
The motor is working. There is debris on the brush rollers & the vacuum itself appears to be dusty.
5 Suggested Answers
  • 1462 Answers
SOURCE: no suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
Posted on May 03, 2007
  • 231 Answers
SOURCE: When using the attachments dirt and dust spew from
thats because your brushroll is still rotating when you use your attachments throwing material from the floor out the wand tube. not much you can do about it on that model.
Posted on Jan 03, 2010
  • 15 Answers
SOURCE: My vacuum isn't cleaning/suctioning very
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Posted on Jul 09, 2011
  • 36 Answers
SOURCE: clean dirt sensor on panasonic bagless vacuum
Did you check to make sure there isn't any small piece of dirt, etc. in the way? Keep working with it; it should reset back to normal
Posted on Jun 07, 2012
My Shark Navigator does not have any suction. The roller brush works. What should I do?
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it.
If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum.
If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
ou can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark+navigator
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 18, 2016 | Shark Vacuums
Brush roller won't turn
Hey, this is Jeremy with Crucial Vacuum,
There are 2 potential reasons as to why your Dirt Devil AccuCharge roller brush is not working:
1) The roller brush may be blocked by debris that was picked up by the vacuum. To remove the blockage, switch your vacuum 'OFF' and unplug before proceeding. Then, lay the vacuum down and try to remove anything that is lodged in the roller brush.
2) If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace if needed.
You can purchase replacement parts for Dirt Devil direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 26, 2015 | Dirt Devil AccuCharge 15.6-Volt Cordless...
How do I get to the belt on my dirt devil
On the bottom of the dirt devil have to remove cover plate with screws and replace belt on motor
Apr 20, 2015 | Dirt Devil Featherlite Bagless Vacuum...
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I placed the new belt on the brush roller like i was suppose to, but brush roller will not turn forward or backward. What am I doing wrong?
Most likely the roller is frozen due to dirt and debris. Follow the instructions to remove the belt and roller. Clean the roller as best you can and at each end where the hard rubber holders are located. Add some WD40 between the brush and these holders and turn by hand until the holders move freely around the brush. Reassemble making sure the belt is on in the correct manner so the brush rotates in the proper direction.
Oct 04, 2010 | Dirt Devil Featherlite Bagless Vacuum...
My bissell vacuum has no suction. the power works and the brush turns but I have no suction. what should I do?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Sep 25, 2010 | Vacuums
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Panasonic MC-V7720 Bagless Upright Vacuum Logo
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
