Macbook pro does not detect digi 002 rack
Hi there. I am running pro tools le 7.3.1 on my macbook pro 2.2GHz Intel Core Duo running mac os x 10.5.5. I have an MBox, MBox 2 and digi 002 rack. MBoxes work fine but the rack is not recognised. When I launch pro tools  with the rack connected a message reads 'Pro Tools hardware is either not installed or used by another program' then the program quits. I have replaced the firewire cable, I have uninstalled and reinstalled the program and I have ensured that other programs such as Ableton Live are not using the hardware but I am getting the same message. Any ideas? With thanks in advance.
  • 3 more comments
  • jesmorrisy Jan 19, 2009
    Hi there.  I am having the same problem.  It is listed in the hardware menu, however protools gives me an error each time I start up- "Hardware not Connected or turned on"  What should I do?
    Thank you:)
    Jessica
  • Dom Harvey Jan 27, 2009
    Dear everyone who has contributed,
    firstly apologies for no reply from me as I have been away and not checking my mail. Thank you to all of you for your most helpful remarks and suggestions. OK, so cackntosh, following your advice I have now at least got the Mac laptop to recognise the 002Rack hardware in the system profiler under firewire (where it did not recognise it previously). I have also added the device to the Audio Midi setup, but after an initial recognition of the hardware under the audio devices panel, I can't get it to recognise it again. Anyway, the program still won't open with the 002Rack, everything still fine with the MBox2. I guess the only thing to do now is to follow your suggestion to upgrade the protools to 7.4. All a bit frustrating as all the hardware works for protools 7.3.1 with MacOS 10.4.11 on my G4 tower. Hope this makes sense. Anything else that anyone might think of would be a greatly appreciated. Otherwise cheers for now.
  • cackntosh
    cackntosh May 11, 2010
    DomMus2,
    A few things come to mind. Did you delete all of the associated preferences before re-installing? Another is that Pro Tools LE 7.3.1 is not supported on Leopard. The fact that you could get it to work at all is something as I kept having to shutdown due to a kernel panic until I upgraded to the 'official' Leopard supported release 7.4.2. Of course you'll need 7.4 first but once you upgrade to 7.4.2, the install includes a new Core Audio Driver which will make it recognise your hardware.
    Also under System Preferences/Other at the bottom, you should see 'Digidesign Digi 002 Rack' when the unit is plugged-in to your firewire input without launching Pro Tools. If it is not being recognised, after a few seconds you will see 'Unable to connect to 'Digidesign Digi Rack 002'.
    You could also check 'Audio MIDI Set-up' in Utilities. Under the tab 'MIDI Devices' you should see icons called 'IAC Driver', a 'Network' icon, and one for your 'Digidesign Digi 002 Rack' and your 'Digidesign Mbox2', complete with a picture of the likeness of both. (There won't be one for your Mbox 1 because it too is no longer supported.)
  • Sean Cole
    Sean Cole May 11, 2010
    Did you get this working in the end?
  • Sean Cole
    Hi DomMus2,
    Goto the Apple>AboutThisMac>MoreInfo... and check in Hardware>Firewire if the Digi002 is showing up. Tip: Disconnect all other Firewire equipment first just to make it easier to detect if it is showing up.
    Let me know what it says.
    Cheers
    Sean
    PiDigital
Yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Posted on Jan 20, 2009
My Digi 002 Rack is "Clicking" (the actual unit).
Hi
First thing to do is a hard reset. Merely unplug the power cord for 4 hours, then power up again.In order to dissipated the remaining current stored in the memory and disconnect all unit connected.
Regards:
votit
Feb 08, 2011 | Digidesign Digi 002 Rack FireWire Pro...
Can i use the 002 rack as a standalone mixer without pro tools running
Unlike some RME products, the 002 rack has no ability to run as a standalone mixer. All routing/mixing is controlled via the pro tools software.
Jan 13, 2011 | Digi 002 Rack FireWire-based Pro Tools LE...
Hi i have digi design rack 002 with pro tools le
Try the other port on the 002. If that doesnt work, I recommend trying the 002 on a computer that does have 400 to see if it will connect then.
If it doesnt, then you may have a couple blown firewire chips inside your 002. It happens, and can be fixed.
Jun 29, 2010 | Digi 002 Rack FireWire-based Pro Tools LE...
Problem detected with audio clock not getting
Having 845GL Intel Motherboard with inbuilt sound card. but enable to load sound and hardware shows no sound device is attached even after reloading of sound from it's motherboard CD. Pl. guide me to solve problem . vyasdeo@rediffmail.com
Aug 08, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
NO AUDIO
Did you solve this problem yet. If not let me kno im looking for a 002 to do some testing plus i need some spare parts.
Feb 11, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Which firewire cable do I use with my Digi 002 console?
If you are using a desktop comupter, you will need any 6-pin to 6-pin connection. If you are using a laptop, you will need any 6-pin to 4-pin connection.
Jan 12, 2009 | Digidesign Digi 002 Rack FireWire Pro...
Broken Digi 002 firewire port
Did you solve this problem yet. If not let me know im looking for a 002 to do some testing plus i need some spare parts.
Dec 19, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Installing Pro tools LE 6.7 on G5
If this was already solved, well, this will help someone else. My guess is your new G5 came with 10.4 or 10.5 and you possibly tried to install LE 6.7 or earlier. This will not work on these OSs. If you have 6.7 you can upgrade to LE 6.9.1 for free and this will solve you problem. If you have LE 6.4 you are screwed and will have fork over $75 to Digidesign to upgrade to 6.9.1...or upgrade to 7.4, which is actually kind of worth it.
Feb 14, 2008 | Digi 002 Rack FireWire-based Pro Tools LE...
Computers & Internet Logo
6,182 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
