My HP dv2400 laptop is not working. It is just over a year old. When I turn it on, the backlights on the keyboard turn on, and the hard drive sounds like it runs, but the screen stays black.
  • spliz9 Dec 04, 2008
    no nothing at all :(
    but it beeps. three times. one long beep followed by two short. i know that's probably not good :(
    New Friend:
  • 50 Answers
Do you get any kind of startup screen when the system is loading?
Posted on Dec 04, 2008
  • Joe Strautmann
    Joe Strautmann Dec 04, 2008
    It very diffucult to troubleshoot this issue like this sorry i could not have been more of help. probably a faulty video card or a bad connection with your monitor. Is there anything you can think of that would have caused this?
My hp dv2000 is almost 2 years old it had been working well but a few days ago it stopped showing the screen anymore it only shows the backlight. before that it was not loading up at all. Now i can hear...
Hello. I could be hard drive failure if you keep hearing noise. What you need to right now is to backup important data ASAP. You can backup files with your Windows built-in tool or backup hard drive without booting Windows.
Choose the one you like and get a new disk. Do fresh install or restore backup image on that drive. Best Way to Backup Hard Drive without Booting Windows
Oct 11, 2017 | HP Pavilion dv2000 Series Laptop Full...
I got this really old HP Pavillion ZD7260us Laptop a friend left it to me with no HDD and no memory.So i went to buy a DDR PC270 512mb SO DIMM memory and an 80gig IDE Hard Drive. So i tried to install it...
try plugging a standard pc keyboard into the ps2 slot ,if it has one, if not use a usb keyboard. That should tell you if the keyboard is malfunctioning. As for using the hard drive with no caddy it should be fine as long as you pad it it securely, to stop it being knocked about etc when moving the laptop. Also you will need to enter the bios and set ideo 0(the hard drive) to auto detect. As it is more than likely detecting the old hard drive in the bios settings not the new one?
Oct 28, 2009 | Computers & Internet
Hp 1245dx backlight not working on keyboard. was
the inverter is likely disconnected, loose, or burnt out. You can purchase a replacement on ebay for your specific model. Then carefully unscrew the plastic frame around your screen until you find identical looking part. Inverter (looks like small flourescent tube) is usually connected via plug-in connectors and doesn't require soldering. Hope this helps.
Oct 14, 2009 | HP Pavilion dv7-1245dx Notebook
Evesham laptop muse/keyboard/restart prob
Operating System Corrupted. Save all your data and use Factory Restore Disks to Restore your Entire System, including Drivers. If you have problems with saving Data on Hard Drive with External USB Drive than it may be a faulty Hard Drive which you can just replace, then reload O.S. .
Aug 20, 2009 | Computers & Internet
My hp laptop screen wont turn on.
You have a bad backlight or backlight inverter , that need to replace. Bring the laptop to expert technician.
Jul 24, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Hp c762nr will not boot and blacklight will not come on when on
open the back case of Hard and Memory..remove the hard drive then remove the memory...after u remove the memory try to clean the memory using a paper eraser then put it back the memory.about hard drive/Hard Disk do not put it back only memory to test and run the unit.if unit is back to power on self test try put it back the hard drive/HDD then try boot all system.if their is message hard fails i think u need to try to replace the Hard Disk...Thanks and Good Luck...GOOD DAY...
May 29, 2009 | HP Compaq Presario C762NR Notebook
PXE-E61: Media Test Failure, check cable.
id open the hard drive bay and remove the drive and then reseat it and then try to reboot the unit. make sure the battery is out and the power unplugged when you take the drive out. if the system errors like that again its either the hard drive or the ide/sata on the mobo. after getting the system up you could use an external drive adapter to try and recover any data off that drive (really doubt itll work if drive is dead)
Feb 02, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
HP dv9000
 Hello jarkk, I believe your problem is with your backlight inverter. the hard drive should be installed for this process of checking it on an external monitor. with the hard drive removed it will not boot to the operating system. with the drive in, use the external monitor. if the monitor works when plugged into the external monitor plug, this will eliminate a bad video card. if the screen is still black on the laptop screen, replace your backlight inverter. the last case cenario is to make sure your backlights are not burnt out.
Sep 11, 2008 | HP Pavilion dv9000z Notebook
I'm afraid you're going to have to replace the keyboard. I really like my Dr. Pepper, and have had to replace three keyboards in two different laptops because of spillage, maybe one of these days I'll learn. Even the smallest amount of liquid will kill a keyboard, and the thing to keep in mind after a spill, is that the keyboard will either work, and may require some cleaning, or not work at all, and require replacement.
Aug 21, 2008 | HP Xb3000 Notebook Expansion Base And...
Won't boot.
Hello Lunartiger, i have one suggestion. My 4 year old toshiba satellite has had the same problem (almost.....). It would not boot or format. the hard drive's running sound was weird. It would do tic-tic-tic... instead of the normal chirrrrrrr.... I thought the hard drive was broken . So i went to a computer shop and replaced its original toshiba hard drive with a cheap refurbished Fujitsu hard drive. It's been working well(maybe faster) since then. If your hard drive sounds different then before, consider buying a new one. search the web for your laptop's motherboard to see where the CMOS bettery is. I used for my laptop but they might not have hp laptops there
Jun 03, 2007 | HP Pavilion ze4115 Notebook
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
