With power in motherboard .. d switch power not function..
I have change the power supply in cpu still desame..
How can fix it
Posted on Dec 04, 2008
Switch from amd to intel motherboard now have no power
No. Power-supplies are compatible with both Intel and non-Intel motherboards. Look near the Intel CPU for a 4-pin "power" connector -- if there is one, connect the cable from the power-supply into that socket.
Jan 12, 2014 | BFG Technologies Computers & Internet
Please clear cmos if system no display after overclocking
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
Mar 25, 2011 | Biostar G31-M7 TE Motherboard
Why wont the mouse,keyboard and monitor not work after cpu,pwer supply install...
If the motherboard used to work with the old cpu and power supply, but does not with the new cpu and power supply, then probably the cpu or power supply is bad.
Why did you change the cpu and power supply?
If the power supply went bad, it could have overloaded the mother board as well as the old cpu.
If you think the old cpu went bad, how do you know it was not actually the motherboard that went bad?
All I can suggest is that you double check all the connections.
If you have USB mouse and keyboard, try a DIN connected pair.
If you are using the onboard graphics, try a PCI express card instead.
Tell us if there is any front light activity from the power switch, drive, etc.?
Dec 21, 2010 | Biostar P4M900-M4 Motherboard
My cp is nt working, the power supply is nt coming in the cp, it is a intel product and 3months old. i need service
have your power supply changed with the same product number (to maintain compatibility). A faulty power supply reduces that amount of power that the board may need and in that case the cp may not function cause it does not get the right amount of power it needs. Also try changing your power outlet source and cord to see if it will help.
good luck
Jul 04, 2010 | Intel DG41RQ Motherboard CPU Bundle - ...
System dead - checked switch, changed Power supply
Sounds like either you have a faulty memory stick, faulty CPU or CPU fan or a faulty Mobo..
Mar 16, 2010 | Computers & Internet
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Motherboard crash
Check your power supply. Do cord accidentally disconnected?
Do you use small AVR? Could it be choking the CPU of power. Check CPU power supply if it ok.
Next thing to check. Cpu unplugged and power off. Ram, video card, PCI card isolate the problem one by one until you get the fault. Or test it to another unit if you can.
Changing motherboard component is impractical actually like transistor.
Sep 06, 2008 | Gigabyte GA-945GZM-S2 Motherboard
Motherboard not functioning
If the power supply had a problem then it is likely that the motherboard and/or the CPU got damage from that. I would check the 12V and the 3.3V lines from the PSU.
Without more information I cannot say specifically what the problem is. You can try disconnecting everything from the motherboard except video card, CPU, and RAM to see if it would work that way. If it does then you can start connecting devices until it does not work any more then you have found the problem. If that does not work at all then unplug the video card and RAM see if anything changes (you should get a beep code without the video or RAM). If nothing changes then either the CPU or motherboard is bad and the only way that I know of to find out which one is to either try the CPU in another motherboard or try a different CPU in that motherboard.
Nov 12, 2007 | Intel Motherboard
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
