Question about Olympus FE-170 Digital Camera
FE-170 - Lens extends & retracts 3 times when powered on.
My FE-170 had been working fine, but when i tried to use it recently, when i power on, the lens extends & retracts 3 times, with orange light blinking, then powers itself off. I have tried replacing the batteries with new ones, but it still does the same thing.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Appears to be power issue in the camera but you can try the lithium AA batteries that are located in the photo section of your stores... they are more powerful than regular AA batteries or else send to repair shop
Posted on Dec 16, 2008
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
My Olympus FE-170 camera will turn on but the lens barrel will not extend and the shutter will not open. It seems like it is stuck.
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Feb 15, 2011 | Olympus FE-170 Digital Camera
Lens wont go in power button wont lite or come on and screen display nothing what is happen to my fe 210 olympus camera
I have the same camera! But my display is broken. :( But it still works. Try plugging in the external video cable to see if you can see the display on your TV.
Make sure the battery is fully charged. If the battery is no longer holding a charge, replace it or use the appropriate AC adapter to power the camera.
Also, remove the memory card if you are using one in you camera.
After you put a freshly charged battery in or plug in the AC adapter, press and hold the power button for at least 3 full seconds. The lens should extend fully. If it doesn't, press the playback [>] button on the back (this should make the lens retract). Then press the power button to shut the camera off. Press the power button again to power it back up and the lens should extend out as normal. You should be OK.
If not, let me know and I'll see what else I can dig up.
The last thing you can try is updating the Firmware. Below is a link to the Firmware update for this camera. Since I don't know what OS you're using, just pick your Operating System and follow the instructions on the pages that follow the link you chose.
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1300
Dec 04, 2010 | Olympus FE-210 Digital Camera
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
Jun 03, 2009 | Olympus FE-170 Digital Camera
When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Nov 11, 2008 | Olympus FE-220 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
Problem in Olympus FE-170 Digital Camera
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 13, 2007 | Olympus FE-170 Digital Camera
Lens wont retract
Lens motor is shot - check out Olympus web site for repair options-not cheap
Jul 04, 2007 | Olympus FE-140 Digital Camera
Olympus FE-170 Digital Camera Logo
171 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
