Question about Texas Instruments TI-92 Plus Calculator
TI-92: Power loss while not in use.
Anyone had a problem with the 92 losing power over short periods of time? I think it might be a bad capacitor or something.
  • Texas Instru... Master
  • 8,068 Answers
You may be right. I have left batteries in my TI92 for years without using it. When I put in fresh batteries, it came back to life. The backup battery of my TI92 (bought a dozain years ago) has not been changed yet.
Hope it helps.
Posted on Sep 02, 2009
Hey i have a 2010 mercury verado 150 hp .when i use the boat i lose voltage and battery power about 3 hours of trolling .I just replaced the battery still draining and loss of volts . Help please
You are using too much power over that period of time. Sure you have nothing else connected to it? If not, then something in your motor ignition circuit is drawing excessive power - not enough to short out battery but enough to drain it prematurely. Igniter? Ignition electronics, if any?
Aug 07, 2017 | Mercury Boating
My car is losing power when running?
it needs a thorough tune up,,,,plugs,wires,distributor cap,coil,etc
Apr 29, 2015 | 2001 Toyota Corolla
2004 chevy trailblazer power loss, high rpms, low ppms
Check the timing chain. Some times the chain will shift with worn teeth and get out of synch. This will cause the engine to lose power and back fire. Sometimes with a flame through the carb. I did that one once. Easy fix if it is the problem.
Oct 28, 2013 | 2004 Chevrolet TrailBlazer
I have alot of CyberDome ll cameras (probably 30) on my system. They are getting older ~ 6-7 years and some are losing color. They still have great picture but when I cycle power to them they have color...
Most likely capacitors failing on the camera process board. They can also cause no picture, dark picture and sync loss. I use freeze spray to try to make the symptoms happen and heat to bring try to isolate it to an area. It's not so easy to change the capacitors if you do find which one (s) though.
Apr 27, 2017 | GE Security Cyberdome Hd 18x D/n Ptz...
Hello, after installing processor, memory module and grahics card, the MB AOpen AK77-333 makes a couple of CPU fan revolutions after it is powered-on and then stops. Thank you for the reply,
That old puppy may have bad Electrolytic Capacitors.
(Radial Aluminum Electrolytic Capacitor)
Specifically the ones in the motherboard voltage regulator circuit, and more specific the ones used for the voltage regulation to the Processor.
(AOpen AK77-333 details,
http://active-hardware.com/english/reviews/mainboard/ak77-333.htm
Go to the bottom of the page to click to the additional information. 7 Pages)
Visual signs of capacitor failure,
http://www.capacitorlab.com/visible-failures/
{ Back in the day there was espionage at a large capacitor company.
An employee tried to abscond with an Electrolytic Capacitor paste formula.
The company got a heads up before this transpired, and she was given a bogus formula.
The formula didn't have the correct chemical composition, and would develop gas after a time period.
The gas (Hydrogen Gas) expands in the capacitor, and causes seals to be compromised, where the paste is then pushed out.
So much paste loss, and the capacitor can operate in a weakened state.
Too much paste loss, and the capacitor fails
The AOpen motherboards were made in this time period, and not to slam AOpen, but they grabbed up on cheap quality capacitors. Guess which ones they got? AOpen is now out of business.
There were 1000's upon 1000's of these Electrolytic Capacitors made, and they are STILL plaguing electronic components today.
Just a heads up if you find problems with other electronic devices, or components also.
(I replaced some in a Modem. Modem has worked great for 2 years now)
http://en.wikipedia.org/wiki/Capacitor_plague }
Problem is that Electrolytic Capacitors do not always show visual signs of failure. The paste can also dry up inside, and no outward visual sign will be apparent.
A) http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
B) http://www.hardwaresecrets.com/article/616
It could also be a bad Power Supply with a weak voltage power rail.
Enough power to light LED lights, and maybe spin fans a few times, but not enough power to turn the Processor on.
1) ALL of the LED light on at once use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 watts of power.
Depends on what processor it is.
AOpen AK77-333?
Socket A (Also known as Socket 462) processor socket. Uses AMD processors with up to a 266MegaHertz Front Side Bus. (266MHz FSB)
AMD Athlon , or Athlon XP, or Duron.
Dec 10, 2010 | AOpen AK77-333 Motherboard
Tv is blinking on and off
I think you have a bad capacitor in the power supply circuit. You need to have a certified technician look at it though. Get someone who is familiar with mitsu's though. Have a great day. Jay
Jun 06, 2010 | Mitsubishi WS-65311 65" Rear Projection...
Still losing power on 92 ford ranger
bad alternator or battery possibly
Aug 22, 2009 | 1992 Ford Ranger
Periodic power loss to ignition on 2000 Tundra.
Check the connections on the battery,It sounds like one or both may be loose.
Jun 02, 2009 | 2000 Toyota Tundra
Power loss
Check the fuel filter it may be blocked.
Jan 17, 2009 | 1992 Honda Civic
Periodic power loss
change the fuel pump/ or maby just the filter, and clean out the throttle body and air filter
Jan 05, 2009 | 1996 Isuzu Hombre
Texas Instruments TI-92 Plus Calculator Logo
169 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
