Question about Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523
Runs but gun dosenot opreate, it is a clarke 130en
The wire wont feed when the trigger is pulled
    Sergeant:
    Champion:
  • 272 Answers
The only things I can think of are:
  • The tension on the coil of welding wire is too tight and needs slackening off.
  • The feed rollers need cleaning and the tension adjusting.
If none of these solutions solve your problem then I can not help you any further.
Posted on Dec 04, 2008
  • James Raymond Williams
    James Raymond Williams Dec 04, 2008
    You could also try cleaning and re adjusting the electrical connection to the trigger of the welding gun.
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
It willnot weld
if it is just not feeding wire, check the tension on feed wheel. Make sure it turns when trigger is pressed. Also make sure you have gas with solid wire. If you have cored wire gas is not needed.
Jan 16, 2012 | Clarke Power Products Clarke 130EN Mig 110...
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
I have a Clarke Mig 130EN Fan Cooled Welder that is not feeding wire and I can't find anyone local to work on it, nor do I know where to go about finding parts. The only Clarke phone number I found...
Hi:
If you are in the USA, check WWW.Praxair.com for your nearest welding store they will help you, Praxair has more than 1000 retail stores in the USA.
If you can make the motor to work just by by-passing the switch then your problem relies on the gun switch, that's an easy fix.
Just an advice; stop buying clarks, it is pretty defficult to obtain speare parts. Lincoln, Miller, Hobart or any other american machine are easier to find parts and are pretty good welders.
Jun 22, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Have a clarke 125en wire feed drive wheels are not turn although it makes the same noise as it did when it worked, it just up and quit
release the tension from the WFR, pull the trigger and check the shaft that the rollers are attached is spinning if yes then the woodruff key is either missing or broken if no then the drive motor needs looking at, the shaft may have broken further along. get an electrician to check it out.
Mar 03, 2011 | Clarke Power Products Clarke 130EN Mig 110...
Need to know how to get my clark welder to weld aluminum model we6527
Using a Spool gun and an adaptor to your welder is better, but you need to open your wallet and spend at least 600 bucks. The modest way to go is:
1) change the gun liner to a teflon kind one instead of steel.
2) Change your drive rolls for knurled one instead of grooved.
3) oversize your contact tip for more wire feed freedom.
4) use straight argon gas.
5) use aluminum 4043 type 035 size.
And always try to maintain your gun lead as straight as you can.
Good Luck!
Jan 24, 2011 | Clarke Power Products Clarke 130EN...
Clark 130en does not feed well. Feeds great on 10
try checking the tension on the feed roller,you may have too much tension which in return will not allow the wire to feed right,check to make sure your feed roller is for the size of wire you are using,next check the tip size for the wire your using.
Mar 17, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Wire stuck in liner and can not get out
if the wire is stuck in the liner, screw the top pieces off the gun, like the contact tip and the diffuser so you can grab the wire with pliers, pull the wire out of the liner with the pliers, make sure the back of the wire is not still connected to the spool!
Apr 11, 2009 | Clarke Power Products Clarke 130EN...
Clarke Power Products Clarke 130EN Wirefeed Welder - 110 Volts, 130 Amps, Model# WE6523 Logo
364 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
