Question about E-Machines T6420 PC Desktop
My computer turn on but the screen its still back
The screen is connect
  • Scott Jelt
    Scott Jelt May 11, 2010
    Have you tried a different monitor to see if it is the PC or the monitor?
  • 199 Answers
Connect it again
Posted on Dec 04, 2008
Will not boot up. blank screen
Can you see any light on your computer? Or hear your computer running? Have you tried turning of the power and turning it back on? Also check if the cables on the back of your monitor are still firmly connected. as well on the computer side.
Listen for the computer if it makes any kind of sounds when you turn it on.
Jan 08, 2015 | Computers & Internet
LG M227WDP turns black a couple of seconds
Do you have the "sleep" mode turned off on the computer?
As well, you can try different screen resolutions and refresh rate settings on the video section of your computer. That might make the connection to the TV more stable.
Nov 27, 2013 | LG M227WD-PZ LCD TV
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
When I connect it to the computer I can view all folders but the screen on the device is not projected the picture
While the frame is connected to a computer, the screen will be inactive. The purpose of connecting it to a computer is only to move files from your computer to the drive on the frame. Once you eject the frame from the computer and turn the frame on, the screen should come back on.
Mar 04, 2011 | PANDIGITAL (DPF802) Digital Picture Frame
My flat screen power switch flashes and no picture
Your Computer is not POSTing, in other words the system is not Passing the Power On Self Test.
So your screen is not receiving a signal from your computer.
Try your screen on another computer if you can.
I have published some guides that will help you in this very situation, they are entitled;
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
What you want to do is to check that all the connections are connected. Push each one in. Start with the screen and then work your back back to the computer chassis.
damnor01
Jan 30, 2011 | Dell Computers & Internet
When i start up my computer its on but nothing shows up on the screen at all. i got the computer to do my online home school work and it just started this last night it turned off and then would turn back...
hi,, please the monitor that connect wire to the Desktop computer if it is connected properly open your computer if you see the memory pull it out then clean it the copper buy using the pencil eraser after that put it back..
regards
Mar 17, 2010 | HP Pavilion Media Center a1330n - AMD...
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Nothing appears on the LCD screen. What should I do?
The camera may have shut off automatically to save power. Press the POWER button to turn it back on. Also make sure the mode dial is turned completely to the desired mode. When the camera is connected to a computer, the LCD screen is disabled. When it is connected to a printer, press any button to display the print progress screen. After a moment, it disappears again.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
E-Machines T6420 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
