Question about EliteGroup P4S5A/DX Motherboard
P4S5A/DX Motherboard ethernet connection
I have been given a computer it has a P4S5A/DX Motherboard
I would like to be able to use it with broadband but it doesn't have a Ethernet connection for me to plug my broadband cable into
Is their a solution for this issue?
if you have a copy of the manual I would be grateful if you could share it with me too
thank you
aprilmay
  • aprilmay292 Dec 04, 2008
    yep thanks to you I have found where it should be.. but there is nothing there.. I pushed the hard plastic tab away and its an empty space..
    Also the link to the Manual download didnt work
    and yep will make sure I rate you when we have finished
    Thanks for your prompt reply
    The download link worked this time. Thank you
  • EliteGroup Master
  • 4,806 Answers
It should have an ethernet port!! its right next to the USB ports, check you have the right cable
get the manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=38&DetailName=Manual&DetailDesc=P4S5A/DX%20%20(V5.1A)&CategoryID=1&MenuID=82&LanID=0
kind regards and please don't forget to rate us
Posted on Dec 04, 2008
  • Lee Hodgson
    Lee Hodgson Dec 04, 2008
    Ok now we have established there is no LAN port there (god knows why!!)
    you will have to go out and buy a PCI lan card, the card goes into the
    PCI slots
    try click on the link again http://www.ecs.com.tw/ECSWebSite/Downloa...
  • Lee Hodgson
    if it won't connect to the link just copy and paste it in to the address bar at the top of your browser
Diogram for mother bord p4s5a to plug in ports
look for download at this link http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
Dec 11, 2013 | EliteGroup P4S5A/DX (ECSP4S5A) Motherboard
Switch Wiring for P4S5A/DX+
go here download manual http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
Apr 19, 2013 | EliteGroup P4S5A/DX Motherboard
ED if a purchesed MOBO it should be writen down in the documentation.
May computer is hang-up after 2 to 3 min on the start-up on the bios
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 30, 2010 | EliteGroup P4S5A/DX Motherboard
Driver USB2 for Motherboard EliteGroup P4S5A/DX, for win XP
You may download technical info and software for your motherboard from the link below directly from the manufacturer.
Download Here
If you find this solution helpful, then please take a moment to rate this post. - Thanks.
Jun 02, 2010 | EliteGroup P4S5A/DX Motherboard
Unable to get on the internet. It says ethernet is unplugged. a friend told me that i should download the driver to my other computer. Then put the harddrive on the other computer that im having problems...
If its saying "Ethernet is unplugged" means its not getting signal from the router to the machine through your LAN cable. Try changing the LAN cable and check your Ethernet settings.
Jan 05, 2010 | EliteGroup P4S5A/DX Motherboard
Connection diagram plug the USB ports to the EliteGroup P4S5A/DX+
Here is a link to the manual for your motherboard. It should show you how to connect your usb cables.
Hope this helps.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=39&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Nov 09, 2009 | EliteGroup P4S5A/DX Motherboard
have u tryed to change it in bios .on start up press del and u will fined
Aug 19, 2008 | EliteGroup P4S5A/DX Motherboard
No power supply activity
check all wiring connections going to the board, also check that the bios jumper is not set to clear bios.
Jan 14, 2008 | EliteGroup P4S5A/DX Motherboard
All i need is a manual
Why can't you download the manual? Should be in .pdf format which I am sure you can read with a mac.
Dec 12, 2007 | EliteGroup P4S5A/DX Motherboard
EliteGroup P4S5A/DX Motherboard Logo
407 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
