Question about Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
Try to load from cd that was load into computer and followed on screen instructions now connect the usb cable from GPS to computer and went to some steps and at one point on screen will saynot communicating with gps memory card. A message says if you continue to get this error, please check the following URL for additional information www.garmin.com/usbgpsfaq. PLease help me out so i can use my Garmin Streetpilot i3 gps. Thankyou, Kenneth/lome I am trying to downlod the USB Driverd CD into my C330, but I keep getting the same message. I used my c330 for the first time yesterday, 7/12/08. I had no problems with it all day as I traveled through Lancaster PA, however, when I started home, about 10 miles from destination, the system shut itself off. I turned it back on, however, it kept shutting back off. Now I am unable to get it charged. I took the from off and pushed the reset button, but it still will not charge. I don't know what else to do. Please assist. Wina Patey I am attempting to load new upgraded info into my C330. The DPS driver is loaded into my PC, the DPS cord is connected to the C330. Attempted to go to the next step and get an error indication. that will not go away and keeps popping up when clicking on to the "Next" indicator H E L P
    Genius:
  • 1,689 Answers
Hi had a similar problem with a GPS. I had to give it in for service. As it turned out, the power inverter board had to be changed. The cost of the repair was about 1/2 the price of a new one.
My GPS was cutting in and out at times. I finaly died and would not start at all.
Jerry G.
Posted on Dec 04, 2008
Error message
Install the Garmin City Navigator Cd to your pc and then connect ur garmin to ur pc with the USB cable.
You might have to unlock the maps with information provided with ur garmin like ur unit ID and ur unlock code.
Another possiblity is that ur memory card is gotten corrupted so try installing it on a different micro sd card.
Let us know if u have any luck.
Oct 03, 2008 | Garmin StreetPilot i3 GPS Receiver
Sounds like your battery died and there's no juice to it. When the battery is low, the unit shuts itself off and has a hard time starting up. If possible, try plugging in your unit with a USB cable from the computer and leave the computer on for a few hours and see if that doesn't solve the problem. When in the car, sometimes the cigarette lighter socket comes loose.
Regarding your i3, the USB drivers must be loaded BEFORE you connect your garmin. If you do not have your USB drivers, you can download them from:
http://www8.garmin.com/support/collection.jsp?product=010-00434-00
Also, why would you need to upload maps? The i3 comes pre-loaded.
Jul 13, 2008 | Garmin StreetPilot C330 GPS Receiver
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
A way around this is to insert the SD Card into the computer (SD Card reader), point the directory to the card and install the maps like that. I had to do that the first time I bought my unit because I couldn't figure it out and got frustrated. So I thought of this easy work-around.
Dec 22, 2007 | Garmin iQue 3600 GPS Receiver
I had this problem and the solution was to get a PCI USB card for my computer. My computer's motherboard didn't properly use USB and the Garmin GPS could never talk to the computer.
You can get a PCI USB card cheaply at nearly any good computer / electronics store, or even on Ebay. Once installed, just plug the USB cable into the socket on the PCI card and try the GPS again.
Dec 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin i2/i3
Either you have a bad micro SD card or you are loading more data than the card can hold.
You will need slightly less than 2GB of memory load load USA and Canada all together at the same time.
You can also try buying an external card reader and instead of loading to the garmin load the map data onto the micro SD card from the reader.
Dec 03, 2007 | Garmin StreetPilot c340 GPS Receiver
haveing a hard time trying to download any updates. I dont have the disk eather for my unit. I have the streetpiolt 2720
Sep 24, 2007 | Garmin StreetPilot i3 GPS Receiver
Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Sep 22, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
186 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
