Question about Teac Audio Players & Recorders
My teac esoteric p700 have problem to play cd.. i have the impression the transport skating in the box. And if the prob comme with clean the laser transport How to made that(Add oil or other thing) And how to say if the laser is in the problem did exist cd to test the laser?
5 Suggested Answers
  • 33 Answers
SOURCE: Suddenly X bo x sysytem will not read disks
its the eye you need to replace the eye of the x-box I had that problem too replaced the eye and it was fixed call microsoft I think they got extras I got my eye out of my old x-box good luck ~Grim
Posted on Apr 20, 2007
  • 77 Answers
SOURCE: Laser pickup assembly
you should look on ebay they might have it there.
Posted on Feb 11, 2008
Nickstar19
  • 417 Answers
SOURCE: Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Posted on Jul 03, 2008
dsom
  • 56 Answers
SOURCE: CD player TEAC DC-D350 When inserting
It must probably be a laser faulty, however it could also be derived from something that you can solve by cleaning.. The laser should be on only with cd inserted.
Posted on Sep 03, 2008
  • 4234 Answers
SOURCE: My Sony cd player spins but won't play. Cleaned
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Posted on Jun 15, 2009
Is the CD player replaceable if we can get the correct CD replacement? I've tried to get the info from TEAC and they don't answer my email.
See if you can get the exact unit on the cheap on ebay. Teac obviously does not give a rat's a-- about your dilemma .
Your laser assembly is fubar and not repairable - not cost effective.
Time to move on after 9 years of use.
Aug 02, 2015 | Teac Audio Players & Recorders
Won't play any disc on any of the 5 slots boom box also has casette player that records
Laser is either dirty, so a lense cleaning disc required. Or the cd transport is kaput. Uneconomical to repair if this is the case
Apr 11, 2014 | RCA RP8085 5-Disc CD Changer
Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | Audio Players & Recorders
Won`t play movie, skipping sound.
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
May 09, 2009 | Mintek MDP-1815 Portable DVD Player
Does not work always says check disc after loading
May 08, 2009 | Zenith DVP615 Portable DVD Player
My dvd player model dvp615 doesn´t play dvd discs. Only play cd´s and mp3 cd´s. Could any help me to get a solution to this problem? Tank you Eddie
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shines. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not apply to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laser head and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
Teac pdh-300
Generally something that is time related with a CD player indicates that there is something stuck in one of the gear teeth that drive the laser back and forth to play different areas of the disc. A very small piece of dirt/sand can get inside and stuck in a gear tooth preventing the laser from moving past that point on the CD, in your case it's about the 40 minute mark........you can try skipping to say the last song on the CD which will advance the laser unit a bit more quickly than if you were to let the disc play through, that might dislodge the piece.
Another scenario could be a cracked gear in the same drive area. This is not as likely as you say it plays for 40 minutes or so. There is a piece that is attached to the laser which has gear teeth in it that mesh with the gears that move it, I'd suspect it's in there.
Make sure you do not have the player plugged in when you open it, the laser is capable of damaging your eyes.
Oct 07, 2008 | Teac PD-H300 CD Player
CD player TEAC DC-D350 When inserting CD >>message 'disc' shows up. Suspect Laser diode faulty. Should the Laser be on only with CD inserted ? or anytime when player is 'ON'...?
Sep 03, 2008 | Teac Audio Players & Recorders
Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
Jan 18, 2007 | Teac MC-D95 CD Shelf System
367 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
