Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
I have the yellow altima vac. for a while now I can not get the darn thing to pick up properly. Or should i say keep it up.. The vac does seem to be getting everything picked up but as soon as you turn it off, you have a mess under the vac.. I have checked for clogks and can't seem to find any.. I have removed the hose, Nothing there.. And yep have removed the yellow thing inside the trash cup.. Is there anything else you could suggest??
  • 1 more comment
  • Anonymous Feb 10, 2009
    I have the yellow Altima as well, I've only had it about 6 months & out of the six months it has only worked properly 3 months, I vacumn everyday..so I have changed all filters, cleaned the roller on the bottom, the brushes on the bottom & I empty the cannister everyday.....when I bought the cleaner, I was sooo happy with the results it gave me, my floor was clean.....now it picks up nothing, basically pushes it around & I can't run it for longer than 10 min. at a time without it smelling hot. Huge disappointment!
  • Cindy Mosley
    Cindy Mosley Feb 23, 2009
    I have the same problems with the yellow altima. How do you change the belt? Cindy8236
  • Anonymous Feb 26, 2009
    I have the same problem with the yellow altima, but I thought that it was that the belt was bad. I went to change it, but I cannot figure out how to get into the darn thing!!
  • 328 Answers
If it smells hot, then there's a strain on the motor no doubt about it. Check the suction channel behind the sole plate and remove all of the hoses to check for a clog. It could well be that there is a clog inside the machine after the dust channel from the beater bar and before the main hose assembly goes into the bin. Usually a wire brush or just a blunt stick can remove clogs but please be gentle.
Belt replacement on the Altimas occur on top of the hood, look for crosshead screws on the left hand side and then possibly on the other side where the pedal release is. Also there may be two crosshead screws on the front where the top of the beater bar housing is on either side.
Posted on Mar 06, 2009
Everytime I got to clean out my vac, I think I've got that big long tube cleared, but I don't! I detach the entire tube, and unscrew the clear attachment that hooks into the back of the vac. I shake it as much as I can and am always amazed at everything that comes out. Then I drop a quarter (or something small and heavy) in one end, and try to shake it out the other. Almost always, my quarter doesn't come out. Sometimes it will shake things loose and I will get even more junk out. I will then take a broom handle and stick thru the tube. I also do this with the smaller tube that hooks into the yellow bottom part of the vac. I don't stop till my quarter goes smoothly from one end to the other. Hope that makes sense. Good luck!
Posted on Apr 05, 2009
I posted my problem with the yellow Altima Eureka.
I cleaned all the filters and changed the belt (U belt for Eureka) by unscrewing the two bolts on the bottom (very easy) and cleaned out any dust around that area and that there are no cloggs in the hose. My vac works just great now. With regular use (about once a week) you should only need to change your belt once a year. with heavier use I would suggest every six months. The belts come two to a pack and are not expensive.
  • Cindy Mosley
    Cindy Mosley Apr 08, 2009
    Make sure you clean out all the filters. The Hepa Filter, and the sponge filter (very important) you can just rinse this one out after you use it, squeeze it dry and put back in. Make sure you take the hose off the back of the vac and make sure it is clear and clean. Change the belt at least once a year and if you use it a lot, about every six months. All these things have really helped my vac operate just great because I had the same problem. Maintenance is very important for the vac.
    I hope all this helps.
    Cindy8236
Shop vac fuse
Very rarely do vacuums have a fuse in them. You probably have a bad switch or possibly a bad motor.
Mar 29, 2014 | Shop-Vac Corporation Bulldog 8 Gallon...
Tip
Vac's that just stop
meany time's i find high priced vac's out by the road,4 the trash man to pickup. each time i c that i stop & pick it up.
about 90%of the vac's just need 1or2 thing to work.
i have never seen ny brand vac that didnt come with a red reset butten.
that seams to do it,but being i just picked it up i cheack 3 things.
the belt &i unstop no matter what.
belt reset switch &clean the dirt out. that allways helps.
but some times i c dead 1s.
thanks
life's handy man
on Mar 04, 2010 | Vacuums
Trigger switch cuts off during use
make sure the filter is washed thoroughly. I have/had the same problem and washing the filter helps a lot - it cuts off if overheating....and avoid picking up really fine dust like after drilling picture hook holes...
Feb 02, 2013 | Dyson DC34 Bagless Cordless Hand Vac -...
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Eureka Altima (yellow)
the hose under your dusting tool, remove that and you should see the clog. i had the same issue and also found that the smell that is emitted went away after i unclogged it
Aug 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Feb 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Not picking up at all...burning smell..belt seems fine.
its one of 2 things, either your hose is blocked or you need a new belt,they do stretch over time. possibly the brushbar needs replacing too.
Iain
Dec 23, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Unintentionally vacuumed up fine silty powder from sanding drywall mud.
hi carol the yellow cylinder with hundreds of holes is the passage of vacuumed air from container as you are aware and understand if you use h/brush and clean outside of cyl of excess fluff etc then use a suitable probe /darning needle or better as i use a screw driver as used by watch makers ? you can poke out all holes and shake the vac now and again to allow any debri to fall thro coned pipe of cyl it is tediouse but a good job done when you come to vac again also may i suggest you remove the lower cover that covers the rollerbrush and you may will find this area is also gunged up to? so pick out and brush clear hope this helps/inspires you to diy maintain the most important tool in home best wishes
Oct 17, 2008 | Dyson DC14 All floors Bagless Upright...
Eureka Altima is smoking!
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=606496
Posted by saysay on May 18, 2008
Help! My vacuum is smoking. It won’t work anymore and starts to smoke as soon as it gets turned on.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Eureka Altima Upright Vacuum Model #2996AVS – it is probably doing 2 things, it could be the belt and or brushroll and the easiest ay to check is to remove the belt and see if the motor smokes, if the motor is fine then buy a new belt and check the brushroll to see if the brushroll spins freely, there are bearings in the brushroll and thread and hair get bound up in the ends and needs to be cleaned out. So #1, check the belt – no smoke from the motor then check the brushroll to see if it spins freely then changed the belt. If the motor smokes check your purchase date it may still be under the one year factory warranty from the dop. #2. Either clean or replace the brushroll and belt. If you have any further questions, feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
236 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
