Question about Mitsubishi VS-5043 50" Rear Projection Television
What do you look for when the tv want stay on?
The unit will come on and after about 3 seconds switches off. The unit was working fine and started doing this in the middle of a program.
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Posted on Aug 26, 2007
TELEVISION IS IN STANDBY WONT SWITCH ON TO PICTURE
First is the set should have a 1 year parts and or labor warranty--second: in order to offer advice or give help I need to know brand and model number.
Dec 06, 2012 | Televison & Video
Technika tv wont stay on
does this mean that when you turn it on by the unit it is fine? If so then what you need to do is a remote reset, to do this turn the tv off at the wall then take the batteries out of the remote, then press all the buttons on the remote working your way from the top to the bottom (and yes sounds bisare i know but all of them) then put the bateries back in and turn on should work if its still turning on by the unit that is
Jul 19, 2009 | GE 13TVR60 Combo
Temp gauge stay on cold.
Switch ig. on, ground the sender unit wire for about 3 seconds see if the temp. gauge moves, if so change sender unit, if not then it is a faulty gauge reader.
Jan 15, 2009 | 2001 Chevrolet Impala
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
TV Switches off then on again.
i think problem with your SMPS power supply unit. Modern tv comes with microprocessor unit which control switch on/off functions. Check SMT transformer. Check Voltages power suplpy unit. contact service centre for further rectification
Dec 22, 2007 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
