Question about Frigidaire FGS365EC Stainless Steel Gas Kitchen Range
Have FGS365EC range with gas sealed burners.  The tray surrounding burners always seems spotted.  manual says soap and water but it just doesn't do it.
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the burners may be pitted. if it can be cleaned its just dirt, soap or water. if it cannot be cleaned or feels rough after you tried to clean it then it is pitted and the only way to fix it would be to replace it.
Posted on Dec 04, 2008
Thermador has had sudden no gas to whole unit
They may have accidentally turned off a little gas cock which is cunningly hidden on the front panel can\'t remember if it\'s top or bottom, it isolates the gas to the main control valve.
Mar 20, 2014 | capital Precision GCR484G 48" Pro-Style...
WMGR 5750BDW replaced burner. now smell gas what do i do ?
check all connections where gas flows mix soap and water and rub it around the connections if this doesn't work call your gas company or call a professional
Jul 21, 2012 | Maytag MGR5750 Gas Kitchen Range
On mine gas toprange one of the burners stoped working. there is a spark, but no gas.
is it a sealed burner and have you cleaned it lately with some type of soap solution or cleaning pad?
Nov 11, 2011 | Kitchen Ranges
Siemans xtronic Cual-Fuel Convenction Range: burners take a very long time to light using the automatic ignition. Clicks for up to 1 minute. every once in awhile it will just light quickly. Burners are...
Might they be too clean? Is it possible that you have soap/food/grease buildup on the ignition points? It sounds like your spark is not strong enough to light the gas.
May 02, 2011 | Siemens HD2515U Stainless Steel Dual Fuel...
The burners on the left side of my burner tray do not come on? Getting out the burner tray seems difficult. What should I do?
Has water from rain or sprinklers gotten on the heater? Sounds like one of the following:
  1. Plugged burner orifices
  2. Plugged burners
  3. Low gas pressure
  4. Bad gas valve
  5. Poor venting
Your best bet is to remove the burner tray. It really isn't that difficult. Follow the owners manual. If you do this yourself, be sure to leak test all gas fittings.
Jun 26, 2010 | Raypak BURNER TRAY W/VALVE NAT 335
Gas burner wont come on ,it just keeps making a clicking sound but doesn`t come on fridgidair
Is the gas shut-off on? (If the problem is with all burners this is the first place to check.) Usually the shut-off is at the back of the unit and you can reach it after removing the bottom storage drawer. Make sure the burner parts are put together properly (some sealed burner units only fit one way). Check that there are no clogs in the burner slits. The clicking is the ignitor trying to ignite the gas, btw.
Additional problems are recommended for professionals. However you can look for a clogged orifice when you disassemble the burner for cleaning.
I hope this helps.
(I don't know of any range that has a separate burner shut-off (just oven shut-offs) but you might check your range.)
Jun 25, 2010 | Frigidaire FGFB75D Gas Kitchen Range
Refurbish a Universal Chef Range by Waste King Universal
use white vingar kills rust dead...lowe's has some stuff in plumbing you can check for gas leaks on the connectors but I always use soap and water look for bubbles and of course gas smell hehe...
check this site see if they may have something on it not sure but you can give it a shot...
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Garland H283 Gas Kitchen Range
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
How do you clean the un-removable burner tops
I have a MGR4452BDW. The burners turn 1/4 turn, then pull out. Yours should too.
Feb 23, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Frigidaire FGS365EC Stainless Steel Gas Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
