Question about Bosch 24 in. SHU53 Built-in Dishwasher
My SHU5314UC/u11 will only work in the power scrub plus mode. All the other buttons dont work Do I have to replace the control modual?
  • aligmelo Jan 14, 2009
    iT ONLY WORKS ON TWO BUTTONS THE POWER PLUS AND THE REGULAR CYCLE.
Ps1400 went dead! Changed ps1400 battery and the light works great for emergency now, but won't work on normal power!! Checked all wiring!! There is a control modual in the fixture that the test button is...
Hi, Once you disconnect the battery this alters the settings in the computer, you need to take it into any dealers & get the computer rechecked that should solve all the problems. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | Cars & Trucks
Tough scrub plus button blinking
I have the dishwasher working again. Now I have a problem because while checking things out I took out the pump sump support bracket part w10300599 and I don't know where to put it back in. Does anyone have a picture of this installed?
Sep 12, 2012 | Maytag Jetclean Plus MDB6769AW Built In...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How to get the samsung intensity mp3 player to work
if u hav a budget 4 it then by at the stores
and if u dont hav any money to buy mp3 then go apply a work and collect money for buying mp3...then done
Nov 27, 2009 | Samsung SGH-D900 Cellular Phone
Replaced toner cartridge and copy had line of toner on edge -
Check the ink modual again.
if the ink is all on the upper and lower lip it needs to be wiped off.
Sometimes when shaking this modual, exessive ink can go on the surface and scrub on the drum itself.
How did you clean the drum?
Nothing should be used except a very soft dry cloth. The toner acts as a lubricant to the cleaning moducal.
Take out the toner modual and see if you can tilt the modual back away so it falls to the back of the modual, this way there will not be so much at the front developer mag roller.
Apr 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Safe Mode
According to Logitech, If you remove the batteries, hold down the # 2 button and then replace the batteries that will boot the remote into normal mode. Also, holding down the power button while replacing the batteries boots the remote into safe mode.
Nov 26, 2007 | Logitech Harmony 360 LCD Remote Control
Bosch 24 in. SHU53 Built-in Dishwasher Logo
63 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
