Question about E-Machines eMachines Desktop PC
EMachine ET1161-01 power up problem
I just installed a brand new eMmachine desk top and connected it to an existing flat screen monitor, Every once in a while when the system is powered up, the monitor light goes very bright on the screen and can not see any characters on screen nor can I use the mouse.
Unless I turn off the breaker and power back up the system the problem will not go away. The system runs Vista software
Help
Alex
  • calexander12 Dec 05, 2008
    I will try what you suggested.
    Genius:
  • 1,061 Answers
I SUGGEST GOING TO MONITOR WEBSITE AND DOWNLOADING(UPDATING)MONITOR DRIVER(S).THERE IS ALSO THE POSSIBILITY OF INCOMPATABILITY WITH VISTE OS.RICHARDM69
Posted on Dec 04, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
New monitor purchased with a package with compaq desk top, but trying to use with a Acer desk top, screen comes on , but then goes completely dark after about two seconds. If switched off then on, again...
Could be a faulty monitor, or could be missing the driver information for the monitor. Usually when you first connect it will use a generic driver to start but then should automatically download and install the correct driver information for the monitor. Could also just be a faulty cable, power or VGA, HDMI, which ever you are using. Try using different cables first, then you can google search for the correct driver and manually install it.
Aug 22, 2010 | HP Compaq Q2159 21.5-Inch Widescreen LCD...
Using two monitors attached to my lap top and can only use one of the two screen
  • Attach two monitor and switch on the laptop
  • automatically second monitor will show diplay
  • if not then find out dual display symbol on the taskbar click on it.
  • window will open select dual monitor
  • click apply
  • if not then right click on desktop --properties--desktop two monitors symbol will see select 2nd monitor
Apr 17, 2010 | E-Machines eMachines Monitor E15T4
Emachine t3092, no video, can't find certain desktop files
If they're not on the drive, they're not on the drive. Your only other option is to search the free disk space for the remainder of those files. For that you can use the free trial of O&O Unerase Personal. I hope you get those files, never fun to lose memories over a peculiar computer issue.
Mar 22, 2009 | E-Machines eMachines Desktop PC
HP Monitor comes on with bright white screen since changing PC
Try using a different wall outlet to plug in your monitor. Believe it or not this actually may help.
What ever breakers you are talking about to get the monitor going doesn't really have anything to do with the drivers. Monitors are "plug and play" meaning the drivers are installed for you when you plug it in. It"s possible you don't have the connections on securely or maybe one of the pins are bent. Does it say "restore active desktop" anywhere on your screen?
Also possible the power supply isn't strong enough for your lcd.
Dec 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hi I live in Australia and have brought D-link dir-300 Wireless G router 1st off I have on screen D-link Quick router setup Quick router set has discovered that you are already connected to a router...
Dlink routers are fairly easy to set up most of the time, I've used several of them over the years. What the heck is this tower you keep speaking of? Is it a second computer or is it THE computer for your desktop monitor. Your explanation leaves a lot to be desired. I've never seen a commercial router that stands up like a tower computer and if you have one, it is probably a pretty expensive unit, so we must clarify and completely understand what you are talking about. You indicate that removing power and cables from the tower would disable your monitor and that makes it sound like the tower IS your computer. Does that make sense to you, it does to me.
Aug 24, 2008 | Computers & Internet
Samsung syncmaster
my samsung 730B moniter will not run how do I fix it?
Dec 28, 2007 | Samsung Syncmaster 730B 17" Flat Panel LCD...
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
