MiTSUBISHI T V WONT TURN ON
I HAVE A MODEL WS-65713. gREEN LIGHT BLINKS. WONT TURN ON THANKS
  • notanera Dec 13, 2008
    tvguy171 is absolutely correct. Just replace the 4 caps in the DM module and this should solve it. I just changed mine last night and is working great now. I'm not a pro but a hobbyist and I took pix on how I did it, if you are interested in doing it yourself as your model is the same as mine.
  • 106 Answers
The problem with your set is 4 capacitors are bad on the "DM: board in the unit. These capacitors are 1000 microfarad at 16 volts. Unless you are experienced, this repair should be done by a qualified tech due to the complexity of getting to the capacitors
Posted on Dec 04, 2008
  • bkeb316716 Mar 29, 2011
    mitsubishi ws 55511 green light blinks any repair info thanks
Mitsubishi WS-65713 Blinking green light. TV will not turn on!
These Mits TV's tend to have power supply problems that are well documented on the web, when the symptom is as you describe. And this assumes no other unusual noises were heard before the TV went into shutdown.
The repairs are fairly straight forward if you are comfortable with electro-mechanical dis-assembly, soldering repair, and re-assembly.
Just do a search on Mitsubishi (your model number) and capacitors.
Dec 21, 2009 | Mitsubishi WS-65713 65" Rear Projection...
Green light won't stop flashing. Unable to turn off/on or reset.
Unplug the unit for 5 minutes then plug it again. Turn it on. If it does not power up, press the SYSTEM RESET button on the front panel with a pointed object such as the point of a pencil or end tip of a paper clip. The green LED light will flash quickly for about a minute then stops. You may turn on the TV then. The changes you made most recently, before using
SYSTEM RESET, may be lost. Changes you made previously, however, are not lost.
Aug 21, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Green light blinking
Diane,
I do not have the service manual but have instructions with pictures. Will email them to you. If you have never soldered check look for instructions on utube and with some practice you will be able to de-solder and solder. A utube video that is great is at http://www.youtube.com/watch?v=I_NU2ruzyc4. Good luck.
Oct 06, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Green blinking light
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
I had the same problem and just fixed it. You likely have 4 bad capacitors in your DM board. To fix you will have to take the DM board out of the TV, de-solder the ones on there and then solder on new capacitors. For those who would like instructions on this leave me your email and I will email them to you. I can't believe I was able to do this but thanks to Jaime for giving me the instructions and checking how to solder on Utube. No I had never soldered before guess it shows you can do it with some effort.
Jul 10, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
http://servicemanuals.vstore.ca/
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi TV
I thpught I sent this to you already?
May 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Please send me the instructions on how to remove and repair the dm board in my mitsubishi ws-65513 tv. The green light keeps blinking. thanks
samzlades@yahoo.com
Mitsubishi WS-65713
Yes Rhonda, first you need to do a self test to show what is going on inside set. You can search threads on test or goto ctechnicians.com. This will put you in the ball park of what is going on.
Dec 29, 2007 | Mitsubishi WS-65713 65" Rear Projection...
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Sep 23, 2007 | Mitsubishi WS-65713 65" Rear Projection...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
