Question about Sharper Image AM/FM Shower Companion Radio with Aluminum Cone Stereo Speakers - Gray and Blue (SI695... Boombox
Cant get it to power up
Problems with Sharper Image AM/FM Shower Companion Radio
Have changed batteries. No luck. Seems dead now. Used to work. Just stopped.
  • Anonymous Mar 22, 2014
    How do I change batteries
  • Anonymous Mar 30, 2014
    how do i set the time
I had exactly the same problem. Here is how I resolved it. 1. There is a reset button inside the battery compartment, in the center, between the C cells. Try pushing it with a paper clip or similar item. 2. If that doesn't work, replace the C cells. 3. If that doesn't work, try replacing the lithium backup battery. It is located between the C cells, in a compartment with an arrow. 4. I finally did all three at the same time, replacing the C cells, lithium battery, and resetting the system. The radio has worked fine for two days now. Good luck.
Posted on Dec 09, 2008
My literati is frozen
Ooh. My 2-year-old Literati did the same thing. Multiple attempts to reset (paperclip in the hole in the back) and to do a hard reset (regular reset + pressing and holding the power button) failed. It wouldn't even turn off; I let the battery run down and recharged through several cycles. No dice. Dead, dead, dead. I suggest that you try the resets, but I fear that your reader is just kaput and will need recycling [MerchSource allegedly will help with that: (800) 374-2744.] Scouring other chat threads didn't seem to yield any other options, but you can look here and maybe have better luck. Sorry.
Dec 26, 2012 | Sharper Image Literati Reader 16375680042...
I have an SI-538 shower companion cd player/fm radio. It works with the adapter plugged in, but it won't run on batteries all of a sudden, even if they are brand new and the correct voltage. What could be...
Check the battery terminals for corrosion, and if possible spray the terminals with some switch/contact cleaner spray... the other problem maybe a bad solder connection on the adaptor socket, not allowing connection from the batteries to the unit.
Aug 27, 2010 | Audio Players & Recorders
Lost the directions to my SI Shower Companion
Do not turn the radio on. Then depress the "mode" button and yo will see all the questions, including time, date, etc. to respond to. Either channel + or - or Tuning + or - (I don;t recall which), will get you the numbers you need, pressing "mode" again will get you to the next module or out entirely.
Apr 03, 2009 | Sharper Image AM/FM Shower Companion Radio...
Sharper Image Beetle projection alarm clock/radio-need ac adap.
You can just buy a regular AC adapter in any store, just ask for a universal AC adapter to make sure it will fit. (you can try Radio Shack, Walmart etc.)
In a universal AC adapter there are multiple plugs and there's switch to set the volts, just find the right plug that fit you Alarm Clock and make sure you set it to 6V and that's it.
Hope it helps
Daniel
Nov 18, 2008 | Sharper Image GT113 Clock Radio
Sharper Image Wireless transmitter deal
Do not restart them with the button, that won't reset settings, unplug everything from power for 5 minutes and plug them back.
Jul 19, 2008 | Audio Players & Recorders
Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Jun 16, 2008 | Sharper Image SA260 CD Shelf System
Sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
Mar 23, 2008 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Sharper Image GT113 Beetle Clock radio
Sorry, no luck with a manual for the GT113, here is the link for the manual for it's replacement, the GT806; http://www.sharperimage.com/us/en/catalog/productdetails/sku__GT806 Check page 16 - hopefully the process is the same on your model for the alarm - other features are definitely different. Please ask again if this doesn't work. Hope this helps :)
Jul 15, 2007 | Sharper Image GT113 Clock Radio
Model si695
This just happened to me. I unscrewed the back (8 screws, each under a rubber pad on the back of the unit) and removed the back cover. I used a jewe;er's Phillips head screwdriver.
You will notice that when you remove the cover, the round watch battery that preserves the memory comes loose. Be sure to remove it so you can reinstall it after you replace the cover.
I didn't really do much except look around.
I pressed the reset button a few times.
I replaced the cover but not the screws. I then replaced the batteries and it worked. I cannot explain why, but it does.
Try this and see if it works for you, too!
Apr 05, 2007 | Sharper Image SI695 AM/FM/TV Radio
259 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
