Question about Microwave Ovens
Microwave Whirpool burned - model #mh6150xhb-0
How can I change (if I can) a burned fuse on a Whirpool microwave (model #mh6150xhb-0)? Thank you.
  • Microwave Ovens Master
  • 9,098 Answers
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find your tech sheet, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
Recurrent Problem with a Whirpool GMH6185 Microwave Oven
The microwave is drawing to much current, the OEM parts don't have the same specifications as the original part and sometimes have slightly different configuration compared to the original which could be causing the very problem you now face. But the miicrowave oven seems to have a secondary problem, burning the fuse. If possible take it back for replacement, I 'am concerned about safety issues.
Apr 15, 2012 | Microwave Ovens
My microwave keeps saying "locked"
I dont know if you have tried it but maybe unplug it for 10 minutes (to let all electricity drain out) then it might reset. If this doesnt help I'm sure sorry.
Mar 07, 2011 | Whirlpool Microwave Ovens
Sharp r-220hw not heating. everything else appears to be working. there is an electrical burn smell. can this just be a fuse problem or is the unit toast.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
0-0-0-0-0-0-0-0-0-
Oct 11, 2010 | Sharp R-220HW Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
The fuse keep burned every day I do replace the fuse, what is the wrong with my Kenmore micrwave 565.61589011 model. Thank you
Chances are that you have a common connection with another plug. Microwave, Fridge etc.. Even if it's not the same plug it's still "In line" meaning that both outlets are on the same breaker. A: Find another outlet to plug your Microwave into or B: Put a surge protector in between the Microwave and the outlet.
Mar 10, 2009 | Kenmore Microwave Ovens
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Whirpool Microwave
You say when you "power on" the fuse blows? If that means when you hit the START button to cook, then you probably have a shorted high-voltage capacitor. If you mean it blows when you plug it in, you probably have a shorted door switch. Your microwave may also have a wiring diagram pasted on the inside of the outer wrapper or in an envelope. That will help in your tests.
Jan 05, 2007 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
325 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
