Question about Sony KV-32S45 32" TV
Blinking standby light on the front of tv...wont turn on no sound
Tv sounds like it will turn on but there is no sound or picture, the standby light on the front of the tv is blinking how can i fix this?
  • hocemjr Dec 04, 2008
    I have a Sony KV-34HS510 with the same problem. The standby light blinks and the tv sounds like it wants to power up but it will not.
  • Sony Master
  • 5,568 Answers
They are dropping like flies -
Just posted this for the same set:
The sound; is it a click or a sharp snapping sound?
The first can be a relay turning on, the second is most likely related to a high voltage discharging.
If it is a relay, then the set could be trying to protect itself from an overload or the power supply has failed; the blinking ON LED is pointing toward that.
If it is a high voltage discharge (you may be able to see it through the vents in the rear housing) then it is possible that an accumulation of dust and household airborne contaminents has created a path that can be removed with some targeted cleaning.
Posted on Dec 09, 2008
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KV-32S45 32" TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
