Question about HP Computers & Internet
My hp 1730 monitor remains black. I can faintly see the display, close-up, but it is close to black. I just tried it on my other computer and it still does not work
    Master:
  • 474 Answers
The screen finely went out and it cant display any more. is it old? do you leave it on alot?
The screen probably burnt out. Or you just have the contrast or brightness turned all the way down.
Check these
Posted on Dec 04, 2008
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Cant display
There might be a problem with the resolution. Check the cover or box of your monitor and find the resolution.
With me the screen goes black when i start any game of higher or lower supported resolution
Sep 23, 2012 | HP 17" 1730 DVI LCD Monitor w/Speakers...
HP 1730 (P9625A) monitor tiene una mancha
While this is a mid-range product it contains certain features that are typically found on higher end products. Mid-range • Viewable Size: 23 in • 1920 x 1080 • Response Time: 6 ms • DVI-D • VGA • 20000000:1 • Power Consumption: 45 W • Weight: 11.9 lbs
Jul 27, 2012 | HP 17" 1730 DVI LCD Monitor w/Speakers...
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
Hp 1730 monitor went black
if after few seconds of display and then the while display turn black, this is the indication of failed capacitor on the LCD circuit board...
you will need to have some technical skill to replace the capacitor.
Jun 21, 2010 | HP 1730 LCD Monitor
I turn on my FLATRON L.1730 SF but after a few seconds it says POWER SAVING MODE and the monitor remains black.
Try selecting a different input from the monitor's menu, perhaps it is set for digital input while you feed it analog VGA signal, or vice versa.
Jan 28, 2010 | LG L1915S 19" LCD Monitor
Analog Dead/DVI OK
Sounds like the video controller board inside the monitor has blown a transistor. They are only about 3mm wide so not easy to spot even if you look closely.
It's a fairly rare fault, though not unknown to happen without reason.
Nov 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Green Light, no Display - Gateway FPD1730
I picked up a FPD1730 monitor for free which was just sitting out in my apartment hallway. I suspected something was wrong and sure e**ugh there was ** backlight, but I could see faint video when I shined a flashlight on it.
A quick Google search of the inverter model # led me to a German forum which suggested replacing the fuse labeled "F1" on the inverter board. I don't have a matching fuse on hand but I bridged the connection with a wire and sure e**ugh the backlight came back on. Short-circuiting like this is definitely **t 100% safe but if you can find a 4A fuse then it's a really cheap and quick fix.
Jul 29, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
95 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
