Question about Elna Heirloom Edition 6005
Failure to form stitches
I have threaded & rethreaded many times checking if this was the problem. also bought new needles today (Universal lasse). I really need this machine going because I know it does really beautiful satin stitch & I need to finish off some applique cushions I am making to sell for Xmas! It has been out of use for a few years but was serviced not long before it was stored. I have oiled it and it doesn't seem to have excess lint. Help!
Julie-Anne Jones, Otaki Gorge, New Zealand.
  • Cody Pryor
    Cody Pryor Mar 01, 2009
    my sewing machine will not create on the bottom of the fabric
I needed to have it fixed as soon as poss so I had to take it to a machine repair man. He saw straightaway that it had a broken gear which was something I could never have sorted myself. Thanks for your reply.
Posted on Dec 04, 2008
Husky 910 overlocker..left needle will not sew stitches...does not unthread just won't form stitches
Be sure to install a brand new needle. Verify it is the correct needle for your machine and it is installed facing the correct direction.
Remove all the thread from your machine. (Clip the threads below the thread spools, RAISE the presser foot, and gently pull all the threads DOWN through the needle--NEVER up!)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify that you are threading each thread in the order specified in the manual--failure to do so will cause your machine to malfunction.
When threading, give each thread an extra little tug when going through the tension disk.
Set all the tensions to the midway point for a 3 or 4 thread overlock.
Test your machine.
If the left needle still fails to stitch, then your machine may need a timing adjustment.
Apr 24, 2017 | Sewing Machines
Husky lock 936 cover stitch troubleshooting
try a new needle
try rethreading that one needle
rethread the looper
if that doesn't help, then the machine may have a timing problem and would have to be checked
Jun 10, 2015 | Husqvarna Huskylock Computerized 936
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a elna 686 serger an it sounds perfect and acts like its sewing but there is no thread staying on the material.... I have tryed to rethread it several times and it does not help at all. What could...
There is several things to check:
Is the needle thread actually going through the needle eye?
Is it chaining off without fabric under the foot? If not, then you need to revisit your threading up, there is a specific sequence that you need to thread the loopers then needles, then pull the threads under the foot, lower pressure foot and press the foot control to make a few stitches, a chain of thread should form.
If this is not happening and you have threaded it up in the right sequence, then check both needles are fitted correctly, fully up into the housing and flat shank to the back. On most sergers the two needles sit at different heights in order to form the stitches. If you haven't done it for a while, change the needles.
If you still can't get a chain of stitching then it is possible that the timing between the loopers and needles has gone out and it will need to be serviced by a technician to get this back right.
Jul 18, 2011 | Elna Sewing Machines
Top and bottom threads do not overlap and catch to make stitch
simpliest thing could be that the needle is in backwards - check it - flat shank to the back.
Or timing is out, ie. when the rotary hook goes around it needs to be timed to when the needle is at its lowest point so that the hook catches the thread at the back of the needle.
Has it jut happened after a jam up/rethreading ? If so, rethread everything, new needle and try again.
If no change to lack of stitching then sounds like timing is off - generally means take it to a professional for repair.
Apr 03, 2011 | Elna Sewing Machines
Sewing machine will not stitch. The thread goes into the material but does not make a stitch. I've changed the needle, cleaned the bobbin, rethread the bobbin and the top thread.??????????????
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Dec 17, 2010 | Singer Confidence 7467 Mechanical Sewing...
Singer Futura 250E - thread is shredding after 5-6 stitches
no damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Apr 03, 2017 | Singer CE-200 Quantum Futura Computerized...
Singer overlocker
Most likely is the left looper thread is trapping the needle threads.
Remove the threads and start over in this sequence....
Left looper - right looper - left needle - right needle.
If you thread the needles before the lower looper, the needle thread wrapped over the looper will be under the looper thread and will never be free to form a stitch, so the threading sequence is critical.
Jun 08, 2008 | Sewing Machines
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Sewing Machines Logo
121 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
