The channel (in the fridge compartment) that collects the water and then drains it is freezing up (including the drain) and causing any additional water to overflow from the channel and run down the back face of the fridge and then freeze under the vege bins. I have just defrosted the fridge but it looks like it is going to do it again. I did notice (the first time it froze) that a horizontal steel bar had slipped down from behind the plastic panel above the channel and was touching the water/ice in the channel but I have now pushed this up behind the panel out of view.
Any Solutions?
-   I also have this problem - I think it can be an ongoing problrm with these fridges but I wold love a solution.
-   ger2
Jan 25, 2009
-   I have the same problem. Water seems to be coming down the back of the fridge and pooling in the tray above the F&V, and freezing under the F&V containers. Sick of water everywhere, and F&V freezing.-   Guest
Jan 14, 2009
-   I also have water and ice under the vegetable drawers. Any solution?
-   Hamelin Hall
My F&P did the same thing for ages and ages. I tried cleaning out the drain hole many times, even with warm water - still refroze water down the back of the fridge and underneath the veggie bins. The advice from fridge repairers was it needed regassing but can't be regassed though because it's the old type of gas which isn't used any more. Repairer's further advice - take it to the dump!
My fridge is leaking water from the roof out of the vent near the front (inside the fridge...
(More)
My fridge is leaking water from the roof out of the vent near the front (inside the fridge compartment). Its a Fisher and Paykel Model number E413
Fisher & Paykel active smart fridge - red light flashing on temp control indicator and...
(More)
Fisher & Paykel active smart fridge - red light flashing on temp control indicator and beeping when opening door (model E442BRT)
my brand new fisher and paykel fridge is not cooling as it should after 3 hours of operating? does...
(More)
my brand new fisher and paykel fridge is not cooling as it should after 3 hours of operating? does it take longer to cool?
My F & P Fridge works well but the interior shlves and baskets have deteriorated. Where can...
(More)
My F & P Fridge works well but the interior shlves and baskets have deteriorated. Where can I get replacement parts?
